Replacing the Wi-Fi module on why! W253EU
    1. Replacing the Wi-Fi module on why! W253EU, Battery from why! Remove W253EU: step 1, image 1 of 3 Replacing the Wi-Fi module on why! W253EU, Battery from why! Remove W253EU: step 1, image 2 of 3 Replacing the Wi-Fi module on why! W253EU, Battery from why! Remove W253EU: step 1, image 3 of 3
      • Turn off the computer.
      • Before each operation it is important to start with the removal of the accumulator.
      • Take the slide unlocked into position, remove the battery.
      Ask FixBot
    1. Replacing the Wi-Fi module on why! W253EU, Access to RAM and CPU from why! W253EU: step 2, image 1 of 2 Replacing the Wi-Fi module on why! W253EU, Access to RAM and CPU from why! W253EU: step 2, image 2 of 2
      • Using a Philips #1 screwdriver, unscrew the 5 screws securing the cover.
      Ask FixBot
    2. Replacing the Wi-Fi module on why! W253EU: step 3, image 1 of 3 Replacing the Wi-Fi module on why! W253EU: step 3, image 2 of 3 Replacing the Wi-Fi module on why! W253EU: step 3, image 3 of 3
      • Push the screwdriver a few millimeters under the cover so that it can be touched with your fingers.
      • Now lift the cover carefully.
      • Attention! Disconnect the ventillator cable so that the cover can be completely removed (see next step).
      Ask FixBot
    3. Replacing the Wi-Fi module on why! W253EU: step 4, image 1 of 1
      • Since the ventillator is mounted under the cover, its power supply cable must first be disconnected so that the cover can then be completely removed.
      Ask FixBot
    1. Replacing the Wi-Fi module on why! W253EU, Wi-Fi Module: step 5, image 1 of 1
      • Using a Phillips #1 screwdriver, remove the two screws securing the Wi-Fi module.
      Ask FixBot
Follow these steps in reverse order to reassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 38
All Time: 519
