This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
Go to step 1 ↓The rectifier IC on this PCB fails frequently. You may hear a pop, see some smoke, and the machine will stop working. It is possible that the motor is damaged, causing the PCB to be destroyed; if you are lucky, however, only the PCB is defective. You can replace the entire PCB, although replacing just the rectifier is cheaper. The PCB is labeled Proxxon 28547-28 or 28547-28B.
Tools
Two types of the PCB are shown here. Both can be used.
These PCBs are for the device without cruise control.
Remove the four very long Torx T10 screws next to the power cable that hold the device together.
Pull the device apart until four parts are visible:
Power connector with power switch
Rectifier board
Motor
Drive
Desolder the two power cables.
Desolder the two motor cables.
Image 2 shows a rectified PCB that has already been repaired. Two additional wires were soldered on because the conductive tracks had partially flaked off. You can also use a new PCB.
Follow the steps in reverse order to reassemble your device.
