Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Replacing the Garmin Zumo 396 Power Button
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
100
All Time:
166
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Unfortunately, the Garmin power button is not available as a spare part, so this is an improvised fix without opening the device.
    1. Replacing the Garmin Zumo 396 Power Button, Power button: step 1, image 1 of 2 Replacing the Garmin Zumo 396 Power Button, Power button: step 1, image 2 of 2
      • Cut a block 11 mm x 5.6 mm / 3 mm deep from a piece of hard rubber. I used a seal from a gas can (a door bumper also works).
      Ask FixBot
    2. Replacing the Garmin Zumo 396 Power Button: step 2, image 1 of 2 Replacing the Garmin Zumo 396 Power Button: step 2, image 2 of 2
      • Cut a piece out of an old bicycle inner tube and glue on the rubber block.
      Ask FixBot
    3. Replacing the Garmin Zumo 396 Power Button: step 3, image 1 of 1
      • Trim the edges and test the function and fitment in the Zumo.
      Ask FixBot
    4. Replacing the Garmin Zumo 396 Power Button: step 4, image 1 of 1
      • Then, apply adhesive to the rubber mat only along the outer edge and, after curing, seal the edge again with adhesive (I used T-7000 adhesive).
      • The microswitch can now be actuated again by pressing on the center, and the Zumo 396 is protected against rain once more.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Author
with
Ronny
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 100
All Time: 166
