Replacing the Battery of the Fujitsu Primergy
Featured Document
  1. Replacing the Battery of the Fujitsu Primergy, Open the Case: step 1, image 1 of 1
    • Pull the green tab on the side and pull back the panel
    • Remove the panel and store it somewhere
    • On page 37 of the manual there is a description similar to that of this article
    Ask FixBot
  2. Replacing the Battery of the Fujitsu Primergy, Remove the fan on the CPUs: step 2, image 1 of 1
    • Press the two green tabs and pull up the fan on the CPUs
    • Be careful to take it easy, the fan cable is short (red arrow)
    Ask FixBot
  3. Replacing the Battery of the Fujitsu Primergy, Remove PCIe cards: step 3, image 1 of 2 Replacing the Battery of the Fujitsu Primergy, Remove PCIe cards: step 3, image 2 of 2
    • Press on the green clips
    • Slowly pull the cards out of the slots
    • It would be advisable to connect to the ground first
    Ask FixBot
  4. Replacing the Battery of the Fujitsu Primergy, Remove the battery: step 4, image 1 of 2 Replacing the Battery of the Fujitsu Primergy, Remove the battery: step 4, image 2 of 2
    • Press on the clip (in red) and the battery should come out by itself
    • Insert the new battery
    • Check the polarity, usually the writings must be upwards
    Ask FixBot
By replacing the CMOS battery the settings should remain saved
Special thanks to these translators:
it en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Attached Documents
Marc developer
1,443 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 182
All Time: 4,850
