Up to 20% off select tools
Replacing an Atari Capacitor
Views: 6.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
29
Past 30 Days:
131
All Time:
6,332
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
Before starting this guide you may need some experience with soldering/ desoldering. If you do not know how, you can learn by clicking the link on step 5 (when you have to desolder the aluminum tabs).
    1. Replacing an Atari Capacitor, Atari Lynx: step 1, image 1 of 1
      • Before disassembling your Atari Lynx, be sure the device is powered off.
      • Remove any game in the console by opening the right latch and sliding the game to the right.
      Ask FixBot
    2. Replacing an Atari Capacitor: step 2, image 1 of 1
      • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
      • Pinch the rear panel with your fingers and lift away from the Atari.
      Ask FixBot
    3. Replacing an Atari Capacitor: step 3, image 1 of 1
      • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
      • Be sure not to tear any wires attached to battery panel.
      Ask FixBot
    4. Replacing an Atari Capacitor: step 4, image 1 of 1
      • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
      • Be sure not to tear the speaker wire while removing the control panel.
      Ask FixBot
    1. Replacing an Atari Capacitor, C10 Capacitor: step 5, image 1 of 2 Replacing an Atari Capacitor, C10 Capacitor: step 5, image 2 of 2
      • Desolder the four aluminum tabs and for more information on soldering click here.
      Ask FixBot
    2. Replacing an Atari Capacitor: step 6, image 1 of 1
      • Remove the aluminum back protector to gain access to the C10 capacitor.
      Ask FixBot
    3. Replacing an Atari Capacitor: step 7, image 1 of 2 Replacing an Atari Capacitor: step 7, image 2 of 2
      • Desolder the C10 capacitor.
      Ask FixBot
Author
with
John Lopez
446 Reputation
4 Guides authored
Cal Poly, Team 1-42, Maness Winter 2014 Member of Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 131
All Time: 6,332
