This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Replacing a defective display panel
    1. Replacing a defective display panel, Remove the case screws: step 1, image 1 of 1
      • Close the laptop, place it on its lid, and align it as shown in the image
      • There are three different screw lengths:
      • 4 x PH1 12 mm (orange)
      • 3 x PH1 10 mm (yellow)
      • 4 x PH1 7 mm (green)
      • The screws must be reinstalled in the correct position later, otherwise something can be damaged.
      • Take out the screws and sort them by length.
      Ask FixBot
    2. Replacing a defective display panel, Remove the keyboard: step 2, image 1 of 1
      • Turn the device over and open it.
      • Once the keyboard is detached, you must remove the 4 ribbon cables before you can remove the keyboard!
      • Carefully insert the Jimmy into the gap between the case and the keyboard at the lower right corner of the keyboard.
      • From this position, work your way forward by levering alternately to the left and up until the keyboard is loose on the case.
      Ask FixBot
    3. Replacing a defective display panel, Unplug the keyboard cable and remove the keyboard: step 3, image 1 of 2 Replacing a defective display panel, Unplug the keyboard cable and remove the keyboard: step 3, image 2 of 2
      • There are 4 cables that must be removed!
      • Carefully open the keyboard under the touchpad, move it in the direction of the screen.
      • Use the spudger to lift the black lock on the ribbon cable and carefully pull out the cable. Repeat this for each one of the four ribbon cables.
      Ask FixBot
    4. Replacing a defective display panel, Disconnect the battery: step 4, image 1 of 3 Replacing a defective display panel, Disconnect the battery: step 4, image 2 of 3 Replacing a defective display panel, Disconnect the battery: step 4, image 3 of 3
      • Locate the battery connector.
      • Carefully slide the metal clip (marked blue in the picture) upwards to unlock the connector.
      • Use the spudger to lift the white connector upwards.
      Ask FixBot
    1. Replacing a defective display panel, Remove the screws: step 5, image 1 of 1
      • Carefully remove the covers using tweezers.
      • Remove the two screws. PH1 - 4 mm.
      Ask FixBot
    2. Replacing a defective display panel, Remove the display cover: step 6, image 1 of 2 Replacing a defective display panel, Remove the display cover: step 6, image 2 of 2
      • Place the device opened on its lid!
      • Use the Jimmy to carefully insert it into the gap in the right corner and pry open the bezel in a counter-clockwise direction.
      Ask FixBot
    3. Replacing a defective display panel, Remove the bezel: step 7, image 1 of 1
      • The bezel is still held to the hinges by its curved shape.
      • Carefully move it and lift it upwards to remove it.
      Ask FixBot
    4. Replacing a defective display panel, Preparing the panel: step 8, image 1 of 1
      • Use the tweezers to carefully pull the adhesive strips off the panel's mounting clips.
      Ask FixBot
    5. Replacing a defective display panel, Release the panel screws: step 9, image 1 of 1
      • Unscrew the four 2.5 mm PH1 screws.
      Ask FixBot
    6. Replacing a defective display panel, Disconnect the panel: step 10, image 1 of 2 Replacing a defective display panel, Disconnect the panel: step 10, image 2 of 2
      • Use tweezers to release the adhesive label.
      • Pull the connector upward to disconnect it.
      Ask FixBot
    7. Replacing a defective display panel, Install new panel: step 11, image 1 of 1
      • Connect the panel.
      • Secure it with the 4 screws.
      • Plug in the keyboard and boot the system to check if the panel is properly connected.
      • If it is not working, check the connector.
      • If it is working, remove the protective film.
      • The display cable must be correctly positioned in its guide, otherwise the bezel will not sit flush.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
buntstift
1,293 Reputation
13 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 99
All Time: 340
