Up to 20% off select tools
Replacing a Sprinkler Extension
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
128
All Time:
1,917
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide is intended to show a non expert how to properly replace a broken sprinkler extension. A broad overview of the steps include digging a hole, unscrewing the extension, and replacing the extension. All you need are some basic tools and general knowledge about actions you preform on a daily basis. Before beginning the project, make sure the water is off and check for hazardous insects. Be aware that digging forcefully could damage the pipeline.
    1. Replacing a Sprinkler Extension, Sprinkler Extension: step 1, image 1 of 1
      • Dig a one foot wide hole around the broken sprinkler extension down to the pipe fitting.
      • The pipe fitting is usually about one foot underground.
      Ask FixBot
    2. Replacing a Sprinkler Extension: step 2, image 1 of 1
      • Dig around the pipe fitting with a trowel to provide clear access.
      Ask FixBot
    3. Replacing a Sprinkler Extension: step 3, image 1 of 1
      • Clean the area around the fitting with water until the fitting is mostly free of dirt.
      Ask FixBot
    4. Replacing a Sprinkler Extension: step 4, image 1 of 2 Replacing a Sprinkler Extension: step 4, image 2 of 2
      • Unscrew the sprinkler extension from the pipe fitting.
      • Once the extension is removed, water may come out of the open pipe fitting.
      Ask FixBot
    5. Replacing a Sprinkler Extension: step 5, image 1 of 1
      • Screw the new sprinkler extension in securely.
      Ask FixBot
    6. Replacing a Sprinkler Extension: step 6, image 1 of 2 Replacing a Sprinkler Extension: step 6, image 2 of 2
      • Test the sprinkler to ensure that there are no leaks.
      • Refill the hole tightly.
      Ask FixBot
If you have completed the steps successfully you should have a fully functioning sprinkler extension.
Author
with
Abagayle Serreyn
111 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 128
All Time: 1,917
