Up to 20% off select tools
Replacing a Baseball Bat Grip
Views: 67K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
212
All Time:
67,286
Comments: 0
Go to guide comments
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
You will learn how to change a worn out grip on a baseball bat. When the grip begins to tear or shred is usually when an old bat is thrown away; this repair will help you keep a bat longer with no skills required to replace the grip. You will need a clean flat surface to work on as you are guided through removing the old grip, cleaning the handle, and putting a new grip on.
    1. Replacing a Baseball Bat Grip, Baseball Bat Grip: step 1, image 1 of 3 Replacing a Baseball Bat Grip, Baseball Bat Grip: step 1, image 2 of 3 Replacing a Baseball Bat Grip, Baseball Bat Grip: step 1, image 3 of 3
      • Place the bat on a firm surface with the grip hanging off the edge.
      • Draw a line on the top of the old grip using a marker.
      • Practice caution when using the utility knife.
      • Use the utility knife to cut the tape where you made your mark.
      • Peel off the old grip.
      • Some bats may have an under layer of wrap that will require extra peeling to remove.
      Ask FixBot
    2. Replacing a Baseball Bat Grip: step 2, image 1 of 2 Replacing a Baseball Bat Grip: step 2, image 2 of 2
      • Put on gloves and place the paper towels under the bat handle to catch the excess spilled residue cleaner.
      • Apply the residue cleaner to the handle.
      • Scrub off the residue with a rag.
      Ask FixBot
    3. Replacing a Baseball Bat Grip: step 3, image 1 of 3 Replacing a Baseball Bat Grip: step 3, image 2 of 3 Replacing a Baseball Bat Grip: step 3, image 3 of 3
      • Sit in a chair and hold the bat in-between your legs with the knob facing upwards.
      • Take the pre-wrap, begin at the knob of the bat and wrap downward in a spiraling motion toward the mark.
      • When applying the pre-wrap, be sure to keep it evenly layered as it will quickly get thicker when doubled.
      • Stop applying the prewrap at the marked line.
      Ask FixBot
    4. Replacing a Baseball Bat Grip: step 4, image 1 of 3 Replacing a Baseball Bat Grip: step 4, image 2 of 3 Replacing a Baseball Bat Grip: step 4, image 3 of 3
      • Hold the bat in the same position used for applying the pre-wrap.
      • Apply the electrical tape over the previous wrap using the same motion as before.
      • Be sure to evenly layer the tape to have a smooth wrap all the way down the handle.
      Ask FixBot
    5. Replacing a Baseball Bat Grip: step 5, image 1 of 2 Replacing a Baseball Bat Grip: step 5, image 2 of 2
      • Apply a small piece of electrical tape at the beginning and end of the wrap to fasten it to the bat.
      • Now that your new grip is complete, you're ready to play ball!
      Ask FixBot
Finish Line
9 other people completed this guide.
Author
with
Matthew McNabb
164 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 212
All Time: 67,286
