Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓The iON Air Pro action camera features a PODZ port on the back of the device that allows users to connect compatible accessories, including the Wi-Fi PODZ accessory. If the port becomes damaged, loose, or unable to maintain a reliable connection, replacing it may restore its functionality.
This guide explains how to remove and replace the PODZ port on the iON Air Pro camera. The repair involves removing the outer housing, unscrewing the rear cover, and disconnecting the ribbon cable attached to the port.
Before starting, turn off the camera and remove any connected accessories. Carefully handle the internal components and ribbon cable to prevent additional damage. Opening the camera housing may also affect its water resistance, so ensure that all seals and covers are properly positioned during reassembly.
Remove the 6 screws securing the lens cover bezel using a #00 Phillips screwdriver. This will allow you to remove the bezel and lens cover.
1 Guide Comment
How do you reconnect the ribbon cable to the back of the PODZ port when you reassemble?
