Up to 20% off select tools
Replacing Strings on a Mandolin
Views: 9K
View statistics:
Past 24 Hours:
7
Past 7 Days:
42
Past 30 Days:
194
All Time:
9,012
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide gives step-by-step instructions for replacing strings in the most appropriate manner, ensuring that you can do some seriously righteous jamming on your New Yorker!
    1. Replacing Strings on a Mandolin, Mandolin Strings: step 1, image 1 of 1
      • Place the mandolin on a firm, level surface with adequate lighting.
      Ask FixBot
    2. Replacing Strings on a Mandolin: step 2, image 1 of 1
      • Loosen the tuning nob.
      • Carefully remove the top end of string from the tuner in the mandolin head.
      Ask FixBot
    3. Replacing Strings on a Mandolin: step 3, image 1 of 1
      • Unhook the old string from the tail of the mandolin.
      • Remove the string from the bottom.
      Ask FixBot
    4. Replacing Strings on a Mandolin: step 4, image 1 of 1
      • Select a new string, and then insert the bottom end of it through the bridge at the tail.
      Ask FixBot
    5. Replacing Strings on a Mandolin: step 5, image 1 of 1
      • Secure the string to the tail by looping it over the hook.
      Ask FixBot
    6. Replacing Strings on a Mandolin: step 6, image 1 of 1
      • Pulling the string taut, bring its top end across the nut and into the tuning peg.
      Ask FixBot
    7. Replacing Strings on a Mandolin: step 7, image 1 of 1
      • Run the line through the tuning element at the head of the mandolin, as pictured. Be sure to pull the string away from the headstock.
      Ask FixBot
    8. Replacing Strings on a Mandolin: step 8, image 1 of 2 Replacing Strings on a Mandolin: step 8, image 2 of 2
      • Pull the string down, towards the fretboard, and run the string underneath itself.
      • Pull the string tight so that it wraps around the tuning peg.
      Ask FixBot
    9. Replacing Strings on a Mandolin: step 9, image 1 of 1
      • Pinch the string over itself to create a knot.
      Ask FixBot
    10. Replacing Strings on a Mandolin: step 10, image 1 of 1
      • Tighten the tuning nob until the desired tension is reached.
      Ask FixBot
    11. Replacing Strings on a Mandolin: step 11, image 1 of 1
      • Clip off any excess string.
      Ask FixBot
    12. Replacing Strings on a Mandolin: step 12, image 1 of 1
      • Optional: Clip the electronic tuning device to the head of the mandolin; use the device to assist in fine-tuning your mandolin.
      Ask FixBot
    13. Replacing Strings on a Mandolin: step 13, image 1 of 1
      • Commence rocking on with your Gretsch New Yorker!
      Ask FixBot
Finish Line
3 other people completed this guide.
Author
with
Drew
125 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 42
Past 30 Days: 194
All Time: 9,012
