Replacing Strings on Floating Tremolo Bridge Guitar
  1. Replacing Strings on Floating Tremolo Bridge Guitar, Strings: step 1, image 1 of 3 Replacing Strings on Floating Tremolo Bridge Guitar, Strings: step 1, image 2 of 3 Replacing Strings on Floating Tremolo Bridge Guitar, Strings: step 1, image 3 of 3
    • Use a string winder to loosen each string by turning the peg counter-clockwise.
    • Once loosened, pull the string out of the tuning peg.
    Ask FixBot
  2. Replacing Strings on Floating Tremolo Bridge Guitar: step 2, image 1 of 3 Replacing Strings on Floating Tremolo Bridge Guitar: step 2, image 2 of 3 Replacing Strings on Floating Tremolo Bridge Guitar: step 2, image 3 of 3
    • Move to the bridge of the guitar and push the strings through.
    • Flip the guitar around and pull the string out of the hole in the back.
    Ask FixBot
  3. Replacing Strings on Floating Tremolo Bridge Guitar: step 3, image 1 of 2 Replacing Strings on Floating Tremolo Bridge Guitar: step 3, image 2 of 2
    • Insert the new strings through the holes in the back.
    • Many strings will be color coded or have guides so you'll know which holes to put each string through.
    • Feed the string through to the other end and pull until the end of the string is reached.
    • You will know if you reached the end of the string if you can't pull any further.
    Ask FixBot
  4. Replacing Strings on Floating Tremolo Bridge Guitar: step 4, image 1 of 1
    • Turn each tuning peg until the holes are perpendicular to the nut.
    • The nut is the piece of wood with grooves that hold the strings.
    Ask FixBot
  5. Replacing Strings on Floating Tremolo Bridge Guitar: step 5, image 1 of 3 Replacing Strings on Floating Tremolo Bridge Guitar: step 5, image 2 of 3 Replacing Strings on Floating Tremolo Bridge Guitar: step 5, image 3 of 3
    • Align each string to the groove in the nut.
    • Insert the strings into the corresponding tuning peg.
    • Leave about an inch or 2 of slack.
    Ask FixBot
  6. Replacing Strings on Floating Tremolo Bridge Guitar: step 6, image 1 of 3 Replacing Strings on Floating Tremolo Bridge Guitar: step 6, image 2 of 3 Replacing Strings on Floating Tremolo Bridge Guitar: step 6, image 3 of 3
    • To tie the knot, begin by looping the string around and then under.
    • Pull up on the string until you can feel tension.
    • Loop the string over and pull.
    Ask FixBot
  7. Replacing Strings on Floating Tremolo Bridge Guitar: step 7, image 1 of 1
    • Tighten the string using the string winder.
    • One or two rotations should do the trick.
    • Be careful not to tighten the stings too much, the strings may snap under excessive tension.
    Ask FixBot
  8. Replacing Strings on Floating Tremolo Bridge Guitar: step 8, image 1 of 1
    • Snip off the excess string at the end.
    • Keep a safe distance when cutting each string. It can snap and hit your face or skin. Be extra careful to protect your eyes.
    Ask FixBot
All that's left to do is tune your guitar and then it will be ready for playing!
PATRICK B COLORINA
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 51
All Time: 780
