Replacing Nokia Classic 2600c-2b Faceplate
  1. Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: step 1, image 1 of 2 Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: step 1, image 2 of 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
    Ask FixBot
  2. Replacing Nokia Classic 2600c-2b Faceplate: step 2, image 1 of 1
    • Remove the back cover to expose the battery.
    Ask FixBot
  3. Replacing Nokia Classic 2600c-2b Faceplate: step 3, image 1 of 2 Replacing Nokia Classic 2600c-2b Faceplate: step 3, image 2 of 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
    Ask FixBot
  4. Replacing Nokia Classic 2600c-2b Faceplate: step 4, image 1 of 2 Replacing Nokia Classic 2600c-2b Faceplate: step 4, image 2 of 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
    Ask FixBot
  5. Replacing Nokia Classic 2600c-2b Faceplate: step 5, image 1 of 1
    • Remove the faceplate with the number pad attached.
    Ask FixBot
  6. Replacing Nokia Classic 2600c-2b Faceplate: step 6, image 1 of 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
    • Apply new faceplate.
    • Follow the instructions in reverse order to reassemble the phone.
    Ask FixBot
Ian VanZandt
699 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 798
