Up to 20% off select tools
Replacing Nintendo DS Battery
Views: 39K
View statistics:
Past 24 Hours:
14
Past 7 Days:
78
Past 30 Days:
393
All Time:
39,273
Comments: 0
Go to guide comments
Completed: 13
13 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 3 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide will walk you through removing and replacing the Nintendo DS battery.
    1. Replacing Nintendo DS Battery, Battery: step 1, image 1 of 3 Replacing Nintendo DS Battery, Battery: step 1, image 2 of 3 Replacing Nintendo DS Battery, Battery: step 1, image 3 of 3
      • Remove the cartridge from the console.
      • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
      • Remove the battery door.
      • In the images, it shows that the fixer is using a flathead screwdriver. This flathead screwdriver will work just like the Phillips #00 Screwdriver.
      Ask FixBot
    2. Replacing Nintendo DS Battery: step 2, image 1 of 1
      • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic opening tool or spudger isn't available, your fingernails may work.
      Ask FixBot
    3. Replacing Nintendo DS Battery: step 3, image 1 of 1
      • Remove the battery from the Nintendo DS.
      Ask FixBot
Make sure to press the power button on the Nintendo DS when finished to confirm the battery is working.
13 other people completed this guide.
Author
with
dnguye26
802 Reputation
4 Guides authored
Cal Poly, Team 18-3, Maness Fall 2009 Member of Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 78
Past 30 Days: 393
All Time: 39,273
