Replacing Nikon Coolpix L20 LCD
  1. Replacing Nikon Coolpix L20 LCD, LCD: step 1, image 1 of 3 Replacing Nikon Coolpix L20 LCD, LCD: step 1, image 2 of 3 Replacing Nikon Coolpix L20 LCD, LCD: step 1, image 3 of 3
    • Okay, so here is Nikon Coolpix L20 purchased for $8.00. Only issue identified is an obviously cracked LCD screen
    Ask FixBot
  2. Replacing Nikon Coolpix L20 LCD: step 2, image 1 of 3 Replacing Nikon Coolpix L20 LCD: step 2, image 2 of 3 Replacing Nikon Coolpix L20 LCD: step 2, image 3 of 3
    • Open the USB cover
    • Remove the two Phillips screws on this side.
    • Remove the one Phillips screw the left side
    • Remove the three Phillips screws on the bottom
    Ask FixBot
  3. Replacing Nikon Coolpix L20 LCD: step 3, image 1 of 3 Replacing Nikon Coolpix L20 LCD: step 3, image 2 of 3 Replacing Nikon Coolpix L20 LCD: step 3, image 3 of 3
    • Open the battery cover.
    • Separate the rear cover from the front by simply gently pulling the two halves apart. You may have to use your fingernails to separate them. Start at the bottom side, by the AC Power cover. Work your way around the bottom.
    • Once the bottom part of the halves is released, gently pull the back cover in an upward motion. The top is secured by some tabs to the front part.
    Ask FixBot
  4. Replacing Nikon Coolpix L20 LCD: step 4, image 1 of 3 Replacing Nikon Coolpix L20 LCD: step 4, image 2 of 3 Replacing Nikon Coolpix L20 LCD: step 4, image 3 of 3
    • With the halves separated, you are now looking at the LCD in the bracket unit.
    • gently fold the LCD toward the ribbon cable out of the bracket unit. DO NOT try to remove the LCD or to loosen the cable.
    • Remove the four screws from the bracket unit.
    Ask FixBot
  5. Replacing Nikon Coolpix L20 LCD: step 5, image 1 of 3 Replacing Nikon Coolpix L20 LCD: step 5, image 2 of 3 Replacing Nikon Coolpix L20 LCD: step 5, image 3 of 3
    • When you remove this screw, make sure that the shield plate on top of the bracket plate, is just slightly pushed out of the way. This will free the bracket plate.
    • After the removal of the bracket plate, you have access to the connector. Move the white clip gently to the lift (upright) position, to free the cable.
    • The LCD should now easily separate from the logic board.
    Ask FixBot
  6. Replacing Nikon Coolpix L20 LCD: step 6, image 1 of 3 Replacing Nikon Coolpix L20 LCD: step 6, image 2 of 3 Replacing Nikon Coolpix L20 LCD: step 6, image 3 of 3
    • For the reassembly, the trickiest part is to bend the LCD ribbon cable so that it fold under the LCD into the bracket unit.
    • Use caution and patience so as to not cut the cable on the bracket unit.
    • After reassembly, you should hopefully have the same result as I did. Total cost $8.00 for the camera, $15.00 for the LCD and one hour of my time...
    Ask FixBot
5 other people completed this guide.
oldturkey03
856,150 Reputation
123 Guides authored
7 Guide Comments
Very good, I really appreciate it. Thank you.
Linda Musnuff - Reply Share
where did you buy the replacement lcd? my l20 broke recently and i’m trying to fix it.
Katherine Lam - Reply Share
@katherinelam had to be either ebay or aliexpress. It's been to long ago to remember for sure.
oldturkey03 - Reply Share
Can confirm that these instructions also work for the Nikon Coolpix L24 model with one or two changes simply related to the amount of screws and the location of them on the casing of the camera. Other than that, just make sure that if your battery compartment does not slide open after you remove the casing or replace the casing then you need to slightly adjust the hinge pin to get it to work. You’ll have to do this with the back basing removed.
Antonio de Abreu - Reply Share
Good evenings, does anybody here know if any other nikon camera lcd screens are compatible with this model?
i'd like to replace my nikon coolpix l20's screen but i cant seem to find any sellers for that model's lcd,
thanks and have a good day yall
Danur S. - Reply Share
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 85
All Time: 9,166
