Replacing Crosley CR42 Needle
    1. Replacing Crosley CR42 Needle, Needle: step 1, image 1 of 2 Replacing Crosley CR42 Needle, Needle: step 1, image 2 of 2
      • The needle is the red plastic piece on the end of the arm. The needle snugly fits over the lower portion of the head, or front end, of the arm.
      Ask FixBot
    2. Replacing Crosley CR42 Needle: step 2, image 1 of 2 Replacing Crosley CR42 Needle: step 2, image 2 of 2
      • While securing the end of the arm by holding the head in place, use your fingernail to push down on the front edge of the needle.
      • The needle should hang, as shown.
      Ask FixBot
    3. Replacing Crosley CR42 Needle: step 3, image 1 of 2 Replacing Crosley CR42 Needle: step 3, image 2 of 2
      • Once the needle snaps free of the head of the arm, remove the needle by pulling down. Take care to only pull on the red portion.
      • WHEN ATTACHING NEW NEEDLE: Slide the back (open U shaped side) of the needle on first, then press to snap the front into place. You should hear a click.
      Ask FixBot
3 other people completed this guide.
Roberto Rosila
328 Reputation
3 Guides authored
Cal Poly, Team 1-38, Maness Winter 2014 Member of Cal Poly, Team 1-38, Maness Winter 2014
CPSU-MANESS-W14S1G38
4 Members
60 Guides authored
1 Guide Comment
On the Crosley CR7002A I am having a problem with the turntable. When the tone arm is moved over any part of the record is slides back to the home position (rest). Is their any adjustment I can make to fix this? Thanks.
thmccullough - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 51
All Time: 6,050
