Replacing Creative Zen X-Fi Motherboard
    1. Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: step 1, image 1 of 3 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: step 1, image 2 of 3 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: step 1, image 3 of 3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      Ask FixBot
    1. Replacing Creative Zen X-Fi Motherboard, Rubber Button Cover: step 2, image 1 of 1
      • The black rubber button pad can be removed by simply picking it up.
      Ask FixBot
    1. Replacing Creative Zen X-Fi Motherboard, Button Input Chip Part 1: step 3, image 1 of 1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      Ask FixBot
    2. Replacing Creative Zen X-Fi Motherboard, Button Input Chip: step 4, image 1 of 1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      Ask FixBot
    1. Replacing Creative Zen X-Fi Motherboard, Access Midsection Plate: step 5, image 1 of 1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      Ask FixBot
    2. Replacing Creative Zen X-Fi Motherboard, Unscrew below Button Chip: step 6, image 1 of 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      Ask FixBot
    3. Replacing Creative Zen X-Fi Motherboard, Unscrew below LCD Screen: step 7, image 1 of 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      Ask FixBot
    1. Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: step 8, image 1 of 2 Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: step 8, image 2 of 2
      • Lift the right edge of the motherboard off the back case.
      • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
      Ask FixBot
Westley Courchene
3,410 Reputation
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,056
