Replacing Atari Lynx Speaker
    1. Replacing Atari Lynx Speaker, Atari Lynx: step 1, image 1 of 1
      • Before disassembling your Atari Lynx, be sure the device is powered off.
      • Remove any game in the console by opening the right latch and sliding the game to the right.
      Ask FixBot
    2. Replacing Atari Lynx Speaker: step 2, image 1 of 1
      • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
      • Pinch the rear panel with your fingers and lift away from the Atari.
      Ask FixBot
    3. Replacing Atari Lynx Speaker: step 3, image 1 of 1
      • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
      • Be sure not to tear any wires attached to battery panel.
      Ask FixBot
    4. Replacing Atari Lynx Speaker: step 4, image 1 of 1
      • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
      • Be sure not to tear the speaker wire while removing the control panel.
      Ask FixBot
    1. Replacing Atari Lynx Speaker, Speaker: step 5, image 1 of 2 Replacing Atari Lynx Speaker, Speaker: step 5, image 2 of 2
      • Remove the logic board from the console.
      • Flip the logic board so the screen is facing down.
      Ask FixBot
    2. Replacing Atari Lynx Speaker: step 6, image 1 of 2 Replacing Atari Lynx Speaker: step 6, image 2 of 2
      • Now you will need to desolder both of the wires connected to the speaker.
      • If you are having trouble desoldering, click here.
      • Finally solder the new speaker back on and follow the previous steps in reverse order.
      Ask FixBot
4 other people completed this guide.
Tyler Williams
372 Reputation
2 Guides authored
Cal Poly, Team 1-42, Maness Winter 2014 Member of Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Members
72 Guides authored
2 Guide Comments
Does anyone know the screw sizes for the lynx 2 console please
RBKing 80 - Reply Share
What are the specs on the speaker? Size? Wattage?
gregory draudt - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 48
All Time: 2,119
