Replacing Antenna on Realistic Weatheradio
Views: 2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
102
All Time:
1,973
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your Realistic Weatheradio is not producing any sound and your battery is still functioning, then the antenna is likely faulty and needs to be replaced. This guide will show users a quick and simple process on how to replace a faulty antenna.
Tools
    1. Replacing Antenna on Realistic Weatheradio, Antenna: step 1, image 1 of 1
      • To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
      Ask FixBot
    2. Replacing Antenna on Realistic Weatheradio: step 2, image 1 of 1
      • Use a Phillips 1X80 screwdriver to loosen the screw located on the bottom right of the back panel.
      • Do not attempt to remove the screw because it will not come out.
      Ask FixBot
    3. Replacing Antenna on Realistic Weatheradio: step 3, image 1 of 2 Replacing Antenna on Realistic Weatheradio: step 3, image 2 of 2
      • Once the screw is loose, slowly pull out the antenna until it is completely out.
      • Once the antenna is out, you can replace it with the new one.
      • Do not force the antenna inside and make sure it is coiled all the way down.
      Ask FixBot
After following these steps, the Realistic Weatheradio should be able to work and function normally.
3 other people completed this guide.
Attached Documents
Matthew
151 Reputation
1 Guide authored
Texas Tech, Team 3-5, Rauch SU 2015 Member of Texas Tech, Team 3-5, Rauch SU 2015
TTU-RAUCH-SU15S3G5
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 102
All Time: 1,973
