Up to 20% off select tools
Replacement thermal fuse on bread machine
Views: 4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
53
Past 30 Days:
206
All Time:
4,031
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
Description of the disassembly and diagnostic steps on Moulinex Homebread bread machine model 573801, ref: OW200030/B72 - 4308R where we come to the conclusion that a thermal fuse is to be replaced. Replacement of this fuse and reassembly.
Two crimping rings are used to connect the fuse with its power cords. These two rings are also to be replaced. You have to choose them with a maximum inner diameter of 3 mm, otherwise we can have difficulty putting on the thermal protection braid after crimping.
Work off power.
    1. Replacement thermal fuse on bread machine, Removing the lid: step 1, image 1 of 2 Replacement thermal fuse on bread machine, Removing the lid: step 1, image 2 of 2
      • Place the cover in an upright position
      • Lift it out of its joint
      Ask FixBot
    2. Replacement thermal fuse on bread machine, Removal of shutters: step 2, image 1 of 2 Replacement thermal fuse on bread machine, Removal of shutters: step 2, image 2 of 2
      • Remove the 4 shutters from the control panel with a very thin screwdriver. This can be difficult or even impossible.
      • Use a forest as a last resort to start a drill.
      • Catch each shutter with the forest
      Ask FixBot
    3. Replacement thermal fuse on bread machine, Removing the control panel: step 3, image 1 of 2 Replacement thermal fuse on bread machine, Removing the control panel: step 3, image 2 of 2
      • With a PH2 screwdriver remove the 4 screws dia 3 x 13
      • Lift and tilt the panel forward
      Ask FixBot
    4. Replacement thermal fuse on bread machine, Removal of the thermal crankcase: step 4, image 1 of 2 Replacement thermal fuse on bread machine, Removal of the thermal crankcase: step 4, image 2 of 2
      • With a PH2 screwdriver remove the 4 upper screws dia 4.2 x 9.5
      • With a PH2 screwdriver remove the 4 lower screws M 4 x 6
      • Lift the crankcase
      Ask FixBot
    5. Replacement thermal fuse on bread machine, Removal of the thermal screen: step 5, image 1 of 2 Replacement thermal fuse on bread machine, Removal of the thermal screen: step 5, image 2 of 2
      • With a PH2 screwdriver remove the 2 screws dia 4.5 x 9.3
      • Tilt and slide the screen down along the two wires of the temperature probe
      • This gives you access to the environment of the two thermal fuses
      Ask FixBot
    6. Replacement thermal fuse on bread machine, Removal of the thermal fuse holding flange: step 6, image 1 of 3 Replacement thermal fuse on bread machine, Removal of the thermal fuse holding flange: step 6, image 2 of 3 Replacement thermal fuse on bread machine, Removal of the thermal fuse holding flange: step 6, image 3 of 3
      • The purpose is to deposit the sheet metal flange that holds the two fuses (two large white and red textile sheaths) and the probe (small white sheath)
      • The maintenance of this flange is ensured by a single sheet metal screw whose head is accessible inside the thermal housing.
      • Use a small ratchet wrench or a short screwdriver with PH2 bit, and continue by hand.
      Ask FixBot
    7. Replacement thermal fuse on bread machine, Diagnosis: step 7, image 1 of 2 Replacement thermal fuse on bread machine, Diagnosis: step 7, image 2 of 2
      • The absence of a power supply requires a diagnosis. The electrical test can be facilitated by opening the back of the splices with a cutting clamp.
      • Open only the strict minimum to be able to pass the touch point of the multimeter.
      • In our case, using the continuity function of the multimeter, it is the thermal fuse protected by the white sheath that is found to fail.
      Ask FixBot
    8. Replacement thermal fuse on bread machine, Replacement of the fuse: step 8, image 1 of 3 Replacement thermal fuse on bread machine, Replacement of the fuse: step 8, image 2 of 3 Replacement thermal fuse on bread machine, Replacement of the fuse: step 8, image 3 of 3
      • Slide the textile sheath to make the fuse and its set rings appear.
      • Cut the wire at the level of the two rings
      • Bare on a length corresponding to those of new rings
      • Set up the three elements and crimp firmly.
      • Check the electrical continuity
      • Replace the textile sheath.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order. Shutters, possibly damaged in step 2, are not strictly necessary. But they make it easier to clean the machine.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Gilles Guérin
355 Reputation
2 Guides authored
1 Guide Comment
Question: si le fusible était défaut, n'y avait-il pas un autre problème qui était la cause du défaut ?
J'arrive à constater le même problème de fusible interrompu sur mon Panasonic SD-2500, grâce a votre guide, mais je me demande s'il suffira de remplacer que le fusible.
Thomas - Reply Share
Past 24 Hours: 7
Past 7 Days: 53
Past 30 Days: 206
All Time: 4,031
