Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Replacement or expansion RAM
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
97
All Time:
907
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
    1. Replacement or expansion RAM, Battery: step 1, image 1 of 3 Replacement or expansion RAM, Battery: step 1, image 2 of 3 Replacement or expansion RAM, Battery: step 1, image 3 of 3
      • Unlock the battery latch on the right.
      • Unlock the battery lock on the left.
      • Remove the battery pack from its slot.
      Ask FixBot
    1. Replacement or expansion RAM, Lower Case: step 2, image 1 of 3 Replacement or expansion RAM, Lower Case: step 2, image 2 of 3 Replacement or expansion RAM, Lower Case: step 2, image 3 of 3
      • Using the Philips # 0 screwdriver, unscrew the 2 screws of the top cover
      • Check the marks indicating the direction in which the cover must be removed.
      • Remove the bottom cover by removing it in the direction of the markers.
      Ask FixBot
    2. Replacement or expansion RAM: step 3, image 1 of 1
      • Then appear the other components of the Laptop.
      Ask FixBot
    1. Replacement or expansion RAM, RAM why! W840xx: step 4, image 1 of 3 Replacement or expansion RAM, RAM why! W840xx: step 4, image 2 of 3 Replacement or expansion RAM, RAM why! W840xx: step 4, image 3 of 3
      • Here is the RAM bar installed by default.
      • Locate and remove the spring blades that hold the memory module in place.
      • Remove the memory module (RAM).
      Ask FixBot
    2. Replacement or expansion RAM: step 5, image 1 of 1
      • Here is the RAM bar out of its location.
      Ask FixBot
To reassemble your device follow the instructions in reverse order
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Felice Suglia
33,655 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 97
All Time: 907
