Up to 20% off select tools
Replacement Ram
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
102
All Time:
972
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Replacement Ram
Tools
    1. Replacement Ram, Ram: step 1, image 1 of 1
      • Turn the laptop upside down. Locate a removable cover, that is screwed shut near the front right of the laptop which is upside down.
      Ask FixBot
    2. Replacement Ram: step 2, image 1 of 1
      • After removing the screw, using your finger slowly lift out and remove the cover.
      Ask FixBot
    3. Replacement Ram: step 3, image 1 of 3 Replacement Ram: step 3, image 2 of 3 Replacement Ram: step 3, image 3 of 3
      • Lift the flap
      • Locate two connectors on both ends of the short end. This will release the ram, if properly done the long end should slightly lift.
      • The ram is to be removed at a 45 degree angle.
      Ask FixBot
    4. Replacement Ram: step 4, image 1 of 1
      • Pull out cleanly and you have now successfully removed the ram.
      Ask FixBot
Author
with
Eric Martinez
667 Reputation
6 Guides authored
USF Tampa, Team 20-5, Remmell Spring 2017 Member of USF Tampa, Team 20-5, Remmell Spring 2017
USFT-REMMELL-S17S20G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 102
All Time: 972
