Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Replace your Desktop PC CPU
View statistics:
Past 24 Hours:
10
Past 7 Days:
54
Past 30 Days:
215
All Time:
757
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 3 - 20 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. Replace your Desktop PC CPU, Open the PC: step 1, image 1 of 2 Replace your Desktop PC CPU, Open the PC: step 1, image 2 of 2
      • First, release the screws from the housing.
      • After that, unplug the cover.
      Ask FixBot
    2. Replace your Desktop PC CPU, Remove the cable: step 2, image 1 of 3 Replace your Desktop PC CPU, Remove the cable: step 2, image 2 of 3 Replace your Desktop PC CPU, Remove the cable: step 2, image 3 of 3
      • Then, you must pull out the hard drive cables.
      • And the cables from the motherboard as well.
      Ask FixBot
    3. Replace your Desktop PC CPU, Remove the CPU cooler: step 3, image 1 of 1
      • Now you need to remove the CPU cooler.
      Ask FixBot
    4. Replace your Desktop PC CPU, Removing the CPU: step 4, image 1 of 2 Replace your Desktop PC CPU, Removing the CPU: step 4, image 2 of 2
      • First, you need to remove the thermal paste with paper.
      • Now, the CPU is removed by lifting a small lever next to the CPU.
      • Now, the CPU must be lifted out of the socket; to do this, you must be careful and lift the CPU from both sides.
      Ask FixBot
    5. Replace your Desktop PC CPU, Install a new CPU: step 5, image 1 of 2 Replace your Desktop PC CPU, Install a new CPU: step 5, image 2 of 2
      • Now you must install the CPU.
      • And apply thermal paste.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Author
with
Raftech07
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 10
Past 7 Days: 54
Past 30 Days: 215
All Time: 757
