Replace RAM memory from why! WDi7SSD
    1. Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: step 1, image 1 of 3 Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: step 1, image 2 of 3 Replace RAM memory from why! WDi7SSD, why! WDi7SSD Opening procedure: step 1, image 3 of 3
      • Make sure the computer is disconnected from the power source.
      • Flip the computer over.
      • Remove the six screws with a 2 mm Allen key.
      • Carefully remove the back panel, as well the left and right panel.
      Ask FixBot
    2. Replace RAM memory from why! WDi7SSD: step 2, image 1 of 1
      • Now flip up the base panel to which all components are attached.
      Ask FixBot
    1. Replace RAM memory from why! WDi7SSD, RAM memory: step 3, image 1 of 2 Replace RAM memory from why! WDi7SSD, RAM memory: step 3, image 2 of 2
      • Disconnect the cable that goes over the RAM bars.
      Ask FixBot
    2. Replace RAM memory from why! WDi7SSD: step 4, image 1 of 2 Replace RAM memory from why! WDi7SSD: step 4, image 2 of 2
      • Press down the small metal springs on both sides and push them to the side.
      • The latch loosens and can be removed.
      • Perform both steps again to remove the second latch.
      Ask FixBot
To reassemble the unit, follow the instructions in reverse order.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,634 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 61
All Time: 411
