This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓Tools:
- Hex key
- Cordless drill with drill bits: 5 and 6.5
- M6 tap
Parts:
- Angle iron
- 4 M6x12 hex socket screws
Unfortunately, after a short time, the motor cover mount, which also serves as a handle, has broken.
The quite thin cast aluminum bars are both broken. The cast aluminum part is attached to the motor and is also the housing for the diaphragm compressor.
The broken-off upper parts are still stuck in the cover.
Spare part not available. Total economic loss?
Cut a piece of angle steel to length that connects both aluminum supports.
Drill 2 holes (6.5 mm diameter) into the angle piece such that one is on the part still attached to the motor and one is on the broken-off piece.
Drill 2 holes with a diameter of 5 mm into each piece of aluminum (the attached part and the broken-off part). Then cut an M6 thread into the aluminum.
Connect all parts using 4 short (12 mm) M6 screws.
