Repairing a Wobbly Piano Bench
    1. Repairing a Wobbly Piano Bench, Repairing a Wobbly Piano Bench: step 1, image 1 of 1
      • Place the bench on an even surface.
      Ask FixBot
    2. Repairing a Wobbly Piano Bench: step 2, image 1 of 1
      • Open and lock its lid. Make sure it stays open during the whole procedure.
      Ask FixBot
    3. Repairing a Wobbly Piano Bench: step 3, image 1 of 3 Repairing a Wobbly Piano Bench: step 3, image 2 of 3 Repairing a Wobbly Piano Bench: step 3, image 3 of 3
      • Unscrew the outer hex nut from one leg using the wrench and take the lock washer out.
      Ask FixBot
    4. Repairing a Wobbly Piano Bench: step 4, image 1 of 3 Repairing a Wobbly Piano Bench: step 4, image 2 of 3 Repairing a Wobbly Piano Bench: step 4, image 3 of 3
      • Take the leg out and unscrew the inner hex nut.
      • Replace the washers with the new ones and re-screw the hex nut tightly.
      Ask FixBot
    5. Repairing a Wobbly Piano Bench: step 5, image 1 of 1
      • Connect the leg to the bench again using the new lock washer.
      • Screw the hex nut a few rounds, but do not tighten it yet.
      • Repeat Steps 3 through 5 for all four legs.
      Ask FixBot
    6. Repairing a Wobbly Piano Bench: step 6, image 1 of 2 Repairing a Wobbly Piano Bench: step 6, image 2 of 2
      • Add a little weight to the chair or push it down with two hands.
      • Turn all four outer hex nuts one round.
      • Make sure the bench is balanced and repeat until all hex nuts are tight.
      Ask FixBot
    7. Repairing a Wobbly Piano Bench: step 7, image 1 of 2 Repairing a Wobbly Piano Bench: step 7, image 2 of 2
      • Close the lid seat on the chair.
      • If the chair is not balanced or if it makes noises, unscrew the outer nut two rounds and repeat Step 6.
      Ask FixBot
You can redo this process every 6 months to make sure your bench is always stable.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 45
All Time: 1,845
