Repairing a Dried-Out Sharpie Marker
Views: 3.1K
View statistics:
Past 24 Hours:
9
Past 7 Days:
50
Past 30 Days:
172
All Time:
3,062
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
A Sharpie can quickly dry out if you leave the cap off too long or use it often, making it weaker or completely unusable. Many Sharpies are thrown away because of this.
If your Sharpie has become dried-out and hard to use, you can use this guide to revive its ink and keep it out of the trash.
For this guide, it is recommended that you wear gloves so that you do not get ink or rubbing alcohol on yourself.
    1. Repairing a Dried-Out Sharpie Marker, Repairing a Dried-Out Sharpie Marker: step 1, image 1 of 2 Repairing a Dried-Out Sharpie Marker, Repairing a Dried-Out Sharpie Marker: step 1, image 2 of 2
      • Remove the cap of the Sharpie.
      Ask FixBot
    2. Repairing a Dried-Out Sharpie Marker: step 2, image 1 of 3 Repairing a Dried-Out Sharpie Marker: step 2, image 2 of 3 Repairing a Dried-Out Sharpie Marker: step 2, image 3 of 3
      • Use a pair of pliers to separate the black part from the grey part of the Sharpie.
      • This can be a little difficult, so you may need to use two pairs of pliers to pull them apart.
      Ask FixBot
    3. Repairing a Dried-Out Sharpie Marker: step 3, image 1 of 2 Repairing a Dried-Out Sharpie Marker: step 3, image 2 of 2
      • Pull out the ink pad.
      • Only touch the sides of the ink pad so that you do not get ink on yourself.
      Ask FixBot
    4. Repairing a Dried-Out Sharpie Marker: step 4, image 1 of 2 Repairing a Dried-Out Sharpie Marker: step 4, image 2 of 2
      • Draw the rubbing alcohol into the syringe.
      Ask FixBot
    5. Repairing a Dried-Out Sharpie Marker: step 5, image 1 of 3 Repairing a Dried-Out Sharpie Marker: step 5, image 2 of 3 Repairing a Dried-Out Sharpie Marker: step 5, image 3 of 3
      • Drip the rubbing alcohol into the part of the ink pad that has a sponge with a hole in its center. Do this until the sponge seems saturated (or about 5 drops).
      Ask FixBot
    6. Repairing a Dried-Out Sharpie Marker: step 6, image 1 of 2 Repairing a Dried-Out Sharpie Marker: step 6, image 2 of 2
      • Put the ink pad back in.
      Ask FixBot
    7. Repairing a Dried-Out Sharpie Marker: step 7, image 1 of 3 Repairing a Dried-Out Sharpie Marker: step 7, image 2 of 3 Repairing a Dried-Out Sharpie Marker: step 7, image 3 of 3
      • Put the black part and grey part of the Sharpie back together.
      Ask FixBot
    8. Repairing a Dried-Out Sharpie Marker: step 8, image 1 of 2 Repairing a Dried-Out Sharpie Marker: step 8, image 2 of 2
      • Put the cap of the Sharpie back on.
      Ask FixBot
    9. Repairing a Dried-Out Sharpie Marker: step 9, image 1 of 1
      • Let the Sharpie set for 1-3 minutes.
      Ask FixBot
Finish Line
3 other people completed this guide.
1 Guide Comment
Si le marqueur a été laissé longtemps sans bouchon, l'alcool marche très bien.
Par contre si il est simplement vidé (beaucoup servi ou servi sur un support poreux, un tissu…) on peut faire la même chose avec de l'encre à marqueur à alcool à la place de l'alcool. Une petit flacon permet de recharger des dizaines de marqueurs.
On peut également recharger la plupart des feutres à eau de la même manière (avec de l'eau du robinet). Certains feutres qui paraissent scellés peuvent en réalité s'ouvrir avec une bonne pince, soit du côté de la tête, soit de l'autre côté (ils sont juste très ajustés par sécurité). Solution très économique et durable pour les feutres des enfants.
Nico - Reply Share
Past 24 Hours: 9
Past 7 Days: 50
Past 30 Days: 172
All Time: 3,062
