This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Repairing a Broken Bumper
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
47
All Time:
47
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
Normally, a window cleaning robot should not fall, but unfortunately, it sometimes happens. A fall puts the bumpers with the spray nozzles at particular risk. In general, many spare parts for the device are available, but this specific part is not always easy to find. It is made of ABS and you can try to glue it. This guide shows you how to do that.
You only need a single tool: a Phillips #2 screwdriver. Keep the screws well organized, as they are of different sizes.
    1. Repairing a Broken Bumper, Removing the mop pad bracket: step 1, image 1 of 2 Repairing a Broken Bumper, Removing the mop pad bracket: step 1, image 2 of 2
      • Empty the fluid reservoir. Remove the mop pad. Unplug the power cord.
      • Place the device with its underside facing up on your workspace.
      • Remove the four screws on the grey mop pad bracket.
      • Lift the grey bracket off.
      • Remove the eight screws underneath the grey bracket.
      Ask FixBot
    2. Repairing a Broken Bumper, Removing the hidden screw on the bottom cover: step 2, image 1 of 2 Repairing a Broken Bumper, Removing the hidden screw on the bottom cover: step 2, image 2 of 2
      • Use a pointed tool to peel off the rubber cap on the underside.
      • Remove the screw underneath.
      • Turn the device over.
      • Carefully lift the top cover slightly. Be careful not to strain the cables underneath too much.
      Ask FixBot
    3. Repairing a Broken Bumper, Flip up the top cover: step 3, image 1 of 1
      • Remove the two cable bundles from their retaining clips.
      • You can now flip up the top cover to access all the components inside.
      • Pay special attention to the blower motor; it sits loosely between two soft rubber seals. It must be tightly enclosed again during reassembly.
      Ask FixBot
    1. Repairing a Broken Bumper, Cracked bumper: step 4, image 1 of 1
      • The crack in the bumper is clearly visible here. There are sensors located underneath the bumper; because of the crack, they can no longer trigger correctly.
      Ask FixBot
    2. Repairing a Broken Bumper, Release the corner sensors: step 5, image 1 of 3 Repairing a Broken Bumper, Release the corner sensors: step 5, image 2 of 3 Repairing a Broken Bumper, Release the corner sensors: step 5, image 3 of 3
      • The bumper is nearly free. It is still attached to the sensors in the corners and the hoses to the spray nozzles.
      • Remove two screws from each of the corner sensors.
      • Lift the sensors off. Let them simply hang by the cables.
      Ask FixBot
    3. Repairing a Broken Bumper, Release the hoses: step 6, image 1 of 1
      • Lift the bumper against light resistance from the right and left sides. Watch out for the hoses to the spray nozzles.
      • Reassembly is easier if you do not disconnect the hoses from the nozzles, but rather at the other end. Carefully cut the cable ties to do this.
      • Carefully remove the bumper.
      Ask FixBot
    4. Repairing a Broken Bumper: step 7, image 1 of 2 Repairing a Broken Bumper: step 7, image 2 of 2
      • Here is the device shown with the bumper removed.
      Ask FixBot
    5. Repairing a Broken Bumper, Bumper glued: step 8, image 1 of 1
      • The bumper is made of ABS, which can be easily glued using a suitable adhesive—in this case, superglue with an activator.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
VauWeh
344,257 Reputation
317 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 47
All Time: 47
