Up to 20% off select tools
Repairing Vizio Television Cable Connection
Views: 19K
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
148
All Time:
19,369
Comments: 8
1 comment on steps, 7 guide comments.
Go to guide comments
Completed: 14
14 people have marked this guide "completed." Will you be next?
Favorites: 14
14 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
Introduction
Go to step 1 ↓
Having problems with your cable connection? Has replacing the cable failed to fix the problem? You may have a broken connection in your motherboard. This guide will help you repair a broken connection from the cable to the motherboard.
    1. Repairing Vizio Television  Cable Connection, Repairing Vizio Television  Cable Connection: step 1, image 1 of 1
      • First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
      • Don't forget the 2 Phillips screws in the motherboard area (circled in red).
      Ask FixBot
    2. Repairing Vizio Television  Cable Connection: step 2, image 1 of 3 Repairing Vizio Television  Cable Connection: step 2, image 2 of 3 Repairing Vizio Television  Cable Connection: step 2, image 3 of 3
      • After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
      • (2) Phillips screws hold down covers over your inputs.
      • Note this screw holds down both covers where they overlap.
      • The bottom cover will not move until the 2 small Phillips screws are removed.
      Ask FixBot
    3. Repairing Vizio Television  Cable Connection: step 3, image 1 of 2 Repairing Vizio Television  Cable Connection: step 3, image 2 of 2
      • Once the covers are all removed, you'll see a big hole where the cable connection is supposed to be.
      • Proceed to solder your new connection in like I did here. If you decide to replace the entire part you'll need to remove the motherboard... We'll save that for a different thread.
      Ask FixBot
    4. Repairing Vizio Television  Cable Connection: step 4, image 1 of 1
      • You can then put it all back together once again in reverse order and enjoy some cable TV!
      Ask FixBot
14 other people completed this guide.
Author
with
Ricky
867 Reputation
3 Guides authored
TechTucson WeFixThat Member of TechTucson WeFixThat
Community
2 Members
48 Guides authored
7 Guide Comments
Are there pics of what needs to be done in order to solder the cable connector correctly?
MistaRite145 - Reply Share
how can I order the part to repair the coax connector for the Vizio 32 inch tv
Steven William Schwenn - Reply Share
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
john kowalski - Reply Share
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
jpfernandez211 - Reply Share
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 148
All Time: 19,369
