Repairing Tire Hole/Puncture
    1. Repairing Tire Hole/Puncture, Repairing Tire Hole/Puncture: step 1, image 1 of 1
      • Wipe the surface of the tire with a rag to remove any loose dirt, rocks, or debris.
      Ask FixBot
    2. Repairing Tire Hole/Puncture: step 2, image 1 of 1
      • Using the air compressor, air the tire up to the original recommended weight for the vehicle.
      • Air is expected to continue to leak out so do not worry if you cannot get it perfect.
      Ask FixBot
    3. Repairing Tire Hole/Puncture: step 3, image 1 of 2 Repairing Tire Hole/Puncture: step 3, image 2 of 2
      • Use the air pressure gauge to make sure the tire is now aired up to its original pressure.
      Ask FixBot
    4. Repairing Tire Hole/Puncture: step 4, image 1 of 1
      • Spray the surface of the tire completely with the soapy water.
      Ask FixBot
    5. Repairing Tire Hole/Puncture: step 5, image 1 of 1
      • Look for tiny air bubbles forming from the leaking air and soap combination, this is where the hole is located.
      Ask FixBot
    6. Repairing Tire Hole/Puncture: step 6, image 1 of 3 Repairing Tire Hole/Puncture: step 6, image 2 of 3 Repairing Tire Hole/Puncture: step 6, image 3 of 3
      • Once the hole is located, remove any foreign objects with the pliers if present.
      • Any object that is stuck in the tire, or puncturing the tire is considered a foreign object. These may include sharp objects, commonly seen as nails, screws, or pieces of metal.
      Ask FixBot
    7. Repairing Tire Hole/Puncture: step 7, image 1 of 1
      • Insert the reamer into the puncture.
      • Work the reamer in and out while twisting to clean and prep the puncture.
      Ask FixBot
    8. Repairing Tire Hole/Puncture: step 8, image 1 of 1
      • Put the plug into the insertion tool.
      Ask FixBot
    9. Repairing Tire Hole/Puncture: step 9, image 1 of 1
      • Insert the plug into the punctured area, leaving about ¼ inch of the plug above the surface of the tire.
      • Yank the insertion tool so the plug remains in the tire, but the tool releases.
      • Cut the remaining plug so it is flush with the tire.
      Ask FixBot
    10. Repairing Tire Hole/Puncture: step 10, image 1 of 1
      • Refill the tire to the proper pressure.
      Ask FixBot
    11. Repairing Tire Hole/Puncture: step 11, image 1 of 2 Repairing Tire Hole/Puncture: step 11, image 2 of 2
      • Use the air pressure gauge to make sure that the tire is back to its original air pressure.
      Ask FixBot
5 other people completed this guide.
Jaylynn Hoffman
293 Reputation
1 Guide authored
2 Guide Comments
i work at discount tire and this is not a department of transportation approved fix and and repuidiple tire dealer will tell you they cannot put a tire back on if they notice this
redheadmateo - Reply Share
This is a good quick and easy way to fix the problem then later on you can take it to this weird ahh guy and he can fix it
CARTER STOECKLEIN - Reply Share
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 100
All Time: 6,892
