Up to 20% off select tools
Repairing Tent Velcro
Views: 6.6K
View statistics:
Past 24 Hours:
9
Past 7 Days:
41
Past 30 Days:
192
All Time:
6,626
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Parts
Tools
Introduction
Go to step 1 ↓
A loose piece of velcro can leave your tent prey to the wind. Sew it back on using a whip stitch.
While you can glue a piece of velcro back into place, some adhesives may cause the tent material to become brittle and tear. Sewing is a simple alternative.
In addition to velcro, this procedure works for sewing almost any other fabric component of the tent back into place.
    1. Repairing Tent Velcro, How to Sew a Whip Stitch: step 1, image 1 of 2 Repairing Tent Velcro, How to Sew a Whip Stitch: step 1, image 2 of 2
      • Align the two pieces of material you will be stitching together.
      • Thread your needle and tie a knot in the end of the thread.
      • We'll use a bright-colored thread for better contrast, but you may want to select a thread that matches the color of your fabric.
      • Drive the needle into the bottom layer of material from the back side.
      Ask FixBot
    2. Repairing Tent Velcro: step 2, image 1 of 3 Repairing Tent Velcro: step 2, image 2 of 3 Repairing Tent Velcro: step 2, image 3 of 3
      • Pull the needle through the bottom layer of material.
      • Pull the thread taut.
      Ask FixBot
    3. Repairing Tent Velcro: step 3, image 1 of 3 Repairing Tent Velcro: step 3, image 2 of 3 Repairing Tent Velcro: step 3, image 3 of 3
      • Drive the needle down through the top and bottom layers of fabric, close to where the needle came up.
      • The distance between where the needle comes up and goes down will be your stitch length. The smaller the stitch length, the more stitches required—and the stronger the seam.
      • Pull the thread taut on the backside of the bottom material.
      Ask FixBot
    4. Repairing Tent Velcro: step 4, image 1 of 2 Repairing Tent Velcro: step 4, image 2 of 2
      • Continue bringing the needle up and down through both layers of fabric, as in steps 2 and 3 of this guide, working your way around the material.
      • If you are using this stitch as a repair where a stitch already exists, be sure to overlap the existing stitching by several stitches to help prevent it from unraveling.
      Ask FixBot
    5. Repairing Tent Velcro: step 5, image 1 of 2 Repairing Tent Velcro: step 5, image 2 of 2
      • For the final stitch, come up from the back of the bottom material once again.
      • Draw the needle between the two layers of material through the stitch closest to where the needle came up.
      Ask FixBot
    6. Repairing Tent Velcro: step 6, image 1 of 3 Repairing Tent Velcro: step 6, image 2 of 3 Repairing Tent Velcro: step 6, image 3 of 3
      • Slowly start to pull the thread taut. As you pull, you will see a loop form.
      • Draw the needle through the loop.
      • Pull the thread taut, forming a knot.
      • Repeat the process of driving the needle up from behind, drawing it through the stitch, and pulling it through the loop as described in steps 5 and 6 of this guide one more time.
      Ask FixBot
    7. Repairing Tent Velcro: step 7, image 1 of 1
      • Ensure that the stitches are tight.
      • Cut any remaining thread, and admire your handiwork.
      Ask FixBot
Finish Line
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
1 Guide Comment
If you remembered to pack a needle, but forgot a spool of thread, and a field repair is in order: go see whether you packed any dental floss. If so, you have some hardy thread indeed, and if you bought the green minty kind, you may discover a whiff of mint now and again emanating from your repair site. I try to remember to buy the old string type of floss rather than the newer kind with flat bits, but if your needle has a big enough eye, you can thread either sort. Careful now, too thick a needle may give you threading holes larger than you want. If the repair is in a location that may leak, there are a wide variety of different things you can use to seal your sewn repair and enjoy a drier tent interior. As my preference is for canvas tents over nylon, I use beeswax, but I think a silicone spray would nicely seal a repair to nylon.
Brendan - Reply Share
Past 24 Hours: 9
Past 7 Days: 41
Past 30 Days: 192
All Time: 6,626
