Introduction
The Quasar MQ7774XW microwave was introduced in 1984. This replacement repair guide shows the necessary steps that must be taken if sparking occurs on the inside of the microwave.
First check to see if the interior of the microwave is dirty. Food or tin foil could be the reason that the microwave is sparking.
If the interior of the microwave is dirty, clean it. A spotless interior is recommended. The interior should look like the example in the picture.
If the microwave continues to spark after the interior has been cleaned, that could indicate that the diode may be broken. The diode is what attaches the capacitor to the back of the microwave.
A multimeter can be used to measure the resistance of the diode. The multimeter must be on the resistance setting or the diode check setting. If the diode reads zero in both directions, then it is broken.
7 other people completed this guide.
2 Guide Comments
Is the magnetron the failing component if you have this microwave or perhaps a 1983-1985 model quasar brand and the microwave doesn’t turn on after hitting “start”, a timer goes but no microwave heating is engaged?
This might be:
- A broken diode
- A faulty capacitor
- Or something else like a severed wire between the transformer and magnetron, a failing transformer or a failing magnetron.
Always be extra careful when opening a microwave oven as the capacitor may contain a deadly electric charge.
Unplug the microwave for at least 24 hours before opening it to reduce risks and use insulated tools and gloves.
