Up to 20% off select tools
Repairing Quasar Microwave Fan
Views: 2.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
95
All Time:
2,389
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Parts
Tools
    1. Repairing Quasar Microwave Fan, Disassembling Quasar Microwave Outer Cover: step 1, image 1 of 1
      • Disconnect the power supply cord from the outlet.
      Ask FixBot
    2. Repairing Quasar Microwave Fan: step 2, image 1 of 2 Repairing Quasar Microwave Fan: step 2, image 2 of 2
      • Remove the eight screws holding the wood-patterned cover to the microwave frame.
      • The first four screws are located on either side of the microwave front.
      Ask FixBot
    3. Repairing Quasar Microwave Fan: step 3, image 1 of 2 Repairing Quasar Microwave Fan: step 3, image 2 of 2
      • Remove the additional four screws securing the wood-paneled case to the microwave frame.
      Ask FixBot
    4. Repairing Quasar Microwave Fan: step 4, image 1 of 3 Repairing Quasar Microwave Fan: step 4, image 2 of 3 Repairing Quasar Microwave Fan: step 4, image 3 of 3
      • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
      • Lift the case upward slowly until the case is free of the microwave.
      Ask FixBot
    1. Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: step 5, image 1 of 2 Repairing Quasar Microwave Fan, Repairing Quasar Microwave Fan: step 5, image 2 of 2
      • Locate the fan in the newly exposed interior.
      • Try spinning the fan with your finger. If it spins freely, the fan is not jammed.
      • If the fan does not spin freely, locate what is jamming the fan and remove it.
      Ask FixBot
    2. Repairing Quasar Microwave Fan: step 6, image 1 of 1
      • If the fan is not jammed yet still does not work, check that there are no disconnected wires, especially to the fan.
      • In order to work properly, there should be two wires going in and out of the fan. If you are missing either of these wires, locate the loose wire/s and connect them.
      Ask FixBot
Author
with
Melanie
107 Reputation
2 Guides authored
Cal Poly, Team 2-12, Propen Fall 2012 Member of Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 95
All Time: 2,389
