Up to 20% off select tools
Repairing Puppet Strings
Views: 4.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
160
All Time:
4,225
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In order to restring your puppet, you will need:
  • Fishing line
  • Scissors
  • A sewing needle
  • Tape or glue
  • Two equally sized wooden sticks (such as chopsticks or pencils)
Note: The glue, tape, and sticks are only needed if you are restoring a handle, also.
    1. Repairing Puppet Strings, Repairing Puppet Strings: step 1, image 1 of 1
      • Detach the severed/damaged strings. This can be done by cutting them or carefully pulling them out.
      Ask FixBot
    2. Repairing Puppet Strings: step 2, image 1 of 1
      • Thread the fishing line through the needle as you would with thread and tie a simple knot to secure the fishing line.
      • Note: Tying the knot can be tedious, so it may take a few tries.
      Ask FixBot
    3. Repairing Puppet Strings: step 3, image 1 of 1
      • Insert the needle into a secure part of the puppet's feet or other necessary puppet part.
      • Note: The material may resist the needle at first.
      Ask FixBot
    4. Repairing Puppet Strings: step 4, image 1 of 2 Repairing Puppet Strings: step 4, image 2 of 2
      • Pull the needle through the puppet part and tie another simple knot directly onto the location that was threaded through.
      • Note: You may want to tie a few simple knots for extra security.
      Ask FixBot
    5. Repairing Puppet Strings: step 5, image 1 of 1
      • If you need to make a handle, take the two wooden sticks and cross them to where they are perpendicular to each other.
      Ask FixBot
    6. Repairing Puppet Strings: step 6, image 1 of 1
      • Secure the two sticks with tape or glue where the two sticks cross.
      • Note: Tape is a faster fix, but may appear messier.
      Ask FixBot
    7. Repairing Puppet Strings: step 7, image 1 of 1
      • Tie a knot around the stick handle to secure the fishing line. (it may take several knots to secure the fishing line and you can adjust the length as needed with scissors)
      • Note: Repeat the previous steps to other parts of the puppet if necessary.
      Ask FixBot
    8. Repairing Puppet Strings: step 8, image 1 of 1
      • This is what your puppet should look like.
      • Happy puppet-ing!
      Ask FixBot
2 other people completed this guide.
Author
with
Stephanie Gummelt
155 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 160
All Time: 4,225
