Up to 20% off select tools
Repairing Paper Jam
Views: 16K
View statistics:
Past 24 Hours:
4
Past 7 Days:
39
Past 30 Days:
203
All Time:
15,846
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Easy
Repairing Paper Jam
Introduction
Go to step 1 ↓
Sometimes during printing the paper will become jammed inside the printer. There are three places in which paper can become jammed. The following guide shows you the three different ways of removing the jammed paper depending on where the jam occurs.
    1. Repairing Paper Jam, Drum Unit and Toner Cartridge: step 1, image 1 of 1
      • Press the front cover release button.
      • Keep the button pressed and pull the cover toward yourself.
      Ask FixBot
    2. Repairing Paper Jam: step 2, image 1 of 3 Repairing Paper Jam: step 2, image 2 of 3 Repairing Paper Jam: step 2, image 3 of 3
      • With the front cover in the downward position, the drum & toner unit will be visible.
      • Grab the black-and-yellow handle on the unit. Lift unit up and pull it out of the printer.
      Ask FixBot
    1. Repairing Paper Jam, Repairing Paper Jam: step 3, image 1 of 2 Repairing Paper Jam, Repairing Paper Jam: step 3, image 2 of 2
      • DO NOT TOUCH the electrodes on the right inner wall of the printer. Touching these electrodes can cause electrical damage to the printer.
      Ask FixBot
    2. Repairing Paper Jam, Paper Jam Type 1: step 4, image 1 of 3 Repairing Paper Jam, Paper Jam Type 1: step 4, image 2 of 3 Repairing Paper Jam, Paper Jam Type 1: step 4, image 3 of 3
      • If jammed, paper will be visible after removing the drum unit. To clear paper jam, reach into printer and grab a corner of the paper.
      • Proceed to lift paper up and out of the printer.
      • Jammed paper may require an excess amount of force to be removed from printer.
      Ask FixBot
    3. Repairing Paper Jam, Paper Jam Type 2: step 5, image 1 of 2 Repairing Paper Jam, Paper Jam Type 2: step 5, image 2 of 2
      • Grab onto the lift located on the paper tray near the bottom on the front of the printer.
      • Pull the paper tray completely out of the printer by pulling towards yourself.
      Ask FixBot
    4. Repairing Paper Jam: step 6, image 1 of 2 Repairing Paper Jam: step 6, image 2 of 2
      • If jammed paper is visible, grab onto the paper and remove by pulling up and towards yourself.
      • Jammed paper may require a large amount of force to be removed from printer.
      Ask FixBot
    5. Repairing Paper Jam, Paper Jam Type 3: step 7, image 1 of 3 Repairing Paper Jam, Paper Jam Type 3: step 7, image 2 of 3 Repairing Paper Jam, Paper Jam Type 3: step 7, image 3 of 3
      • Located on the back of the printer, open up the cover by grabbing onto the tab and pulling down.
      Ask FixBot
    6. Repairing Paper Jam: step 8, image 1 of 3 Repairing Paper Jam: step 8, image 2 of 3 Repairing Paper Jam: step 8, image 3 of 3
      • In front of you will see two blue tabs, one on the left and right side.
      • First, push the top part of the tab in until the bottom part of the tab lifts up.
      • Grab onto the bottom part of the tab.
      Ask FixBot
    7. Repairing Paper Jam: step 9, image 1 of 2 Repairing Paper Jam: step 9, image 2 of 2
      • Once you have a firm grib of both the right and left tab, lift both tabs up and towards yourself.
      • The fuser cover, which the tabs are connected to, does not come completely out of the printer because it is attached to the bottom by a hinge.
      Ask FixBot
    8. Repairing Paper Jam: step 10, image 1 of 3 Repairing Paper Jam: step 10, image 2 of 3 Repairing Paper Jam: step 10, image 3 of 3
      • If jammed paper is visible, grab onto the top of the paper and pull up until completely removed from printer.
      Ask FixBot
2 other people completed this guide.
Author
with
Nathan Ruiz
186 Reputation
2 Guides authored
Cal Poly, Team 4-14, Forte Winter 2010 Member of Cal Poly, Team 4-14, Forte Winter 2010
CPSU-FORTE-W10S4G14
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 39
Past 30 Days: 203
All Time: 15,846
