Repairing PS4 Bluetooth Antenna from Defect or System fell
    1. Repairing PS4  Bluetooth Antenna from Defect or System fell, Remove the Wi-Fi antenna: step 1, image 1 of 2 Repairing PS4  Bluetooth Antenna from Defect or System fell, Remove the Wi-Fi antenna: step 1, image 2 of 2
      • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
      Ask FixBot
    2. Repairing PS4  Bluetooth Antenna from Defect or System fell: step 2, image 1 of 3 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 2, image 2 of 3 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
      Ask FixBot
    3. Repairing PS4  Bluetooth Antenna from Defect or System fell: step 3, image 1 of 3 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 3, image 2 of 3 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 3, image 3 of 3
      • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
      Ask FixBot
    4. Repairing PS4  Bluetooth Antenna from Defect or System fell: step 4, image 1 of 2 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 4, image 2 of 2
      • Remove the 9.7 mm Torx security screw securing the antenna.
      Ask FixBot
    5. Repairing PS4  Bluetooth Antenna from Defect or System fell: step 5, image 1 of 2 Repairing PS4  Bluetooth Antenna from Defect or System fell: step 5, image 2 of 2
      • Remove the Wi-Fi antenna.
      Ask FixBot
    1. Repairing PS4  Bluetooth Antenna from Defect or System fell, What is Wrong?: step 6, image 1 of 1
      • As you can see there are 2 solder points . the wire must run through the first point to the second point. But when the system fell it broke that connection and Antenna got bent. If at factory the solder points were not correct it will cause the same lag issue with controller and WiFi.
      Ask FixBot
    2. Repairing PS4  Bluetooth Antenna from Defect or System fell, Solder it back: step 7, image 1 of 1
      • This is the easy part. Remove the antenna. Move the wire inbetween the two solder points so it is connecting to the second point. Once there take your soldering Iron and heat up the solder and drag it over the wire to make the connection.
      Ask FixBot
      • Just remember to leave the gap here. Do not bend the antenna to make the points touch your self. The gap that runs through it is there by design and changing that has adverse effects on controller and WiFi . But its that easy. My PS4 now works fine with controller and WiFi . No need for further tear-down and extra parts. Put bottom on. GTGo
      Ask FixBot
40 other people completed this guide.
bdcallen69
1,263 Reputation
1 Guide authored
41 Guide Comments
My console was giving me the same problem aft lots of research i came across ur guide and today i fixed the wifi antenna and its working awesome Thanks alot
Muzaffar - Reply Share
Me podrías compartir la guía?
JasonJam21 Dc - Reply Share
Could you share the guide?
I've run into a similar problem (PS4 won't recognize controllers) but wifi works fine. Is it possible that bluetooth doesn't work but wifi does?
gustavo - Reply Share
I replaced my antenna with a new one. But im still experiencing input lag. What else should I do?
angellom90 - Reply Share
Past 24 Hours: 17
Past 7 Days: 119
Past 30 Days: 532
All Time: 209,778
