Repairing Nokia 6500 Slide LCD
  1. Repairing Nokia 6500 Slide LCD, LCD: step 1, image 1 of 3 Repairing Nokia 6500 Slide LCD, LCD: step 1, image 2 of 3 Repairing Nokia 6500 Slide LCD, LCD: step 1, image 3 of 3
    • Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
    Ask FixBot
  2. Repairing Nokia 6500 Slide LCD: step 2, image 1 of 1
    • Remove four screws using torx 5 screwdriver.
    Ask FixBot
  3. Repairing Nokia 6500 Slide LCD: step 3, image 1 of 3 Repairing Nokia 6500 Slide LCD: step 3, image 2 of 3 Repairing Nokia 6500 Slide LCD: step 3, image 3 of 3
    • Pry each side evenly around its edges. The phone should start to split into two halves.
    Ask FixBot
  4. Repairing Nokia 6500 Slide LCD: step 4, image 1 of 2 Repairing Nokia 6500 Slide LCD: step 4, image 2 of 2
    • The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
    Ask FixBot
  5. Repairing Nokia 6500 Slide LCD: step 5, image 1 of 1
    • Make sure all components stay on each side (see picture).
    Ask FixBot
  6. Repairing Nokia 6500 Slide LCD: step 6, image 1 of 2 Repairing Nokia 6500 Slide LCD: step 6, image 2 of 2
    • Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue.
    • This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
    Ask FixBot
  7. Repairing Nokia 6500 Slide LCD: step 7, image 1 of 2 Repairing Nokia 6500 Slide LCD: step 7, image 2 of 2
    • Carefully pry out the lcd cover.
    • Make sure the board connector pass the cover by angle.
    Ask FixBot
  8. Repairing Nokia 6500 Slide LCD: step 8, image 1 of 3 Repairing Nokia 6500 Slide LCD: step 8, image 2 of 3 Repairing Nokia 6500 Slide LCD: step 8, image 3 of 3
    • Disconnect the LCD connector.
    • Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape.
    • The LCD screen will now be loose and can be removed and replace with the new one.
    Ask FixBot
2 other people completed this guide.
dwi
190 Reputation
1 Guide authored
2 Guide Comments
Great - have screen in. Now, have you ever replaced the port / jack for the charger? Mine will not accept the prong all of a sudden
Brenda Kent - Reply Share
Got new charger port in 2017, now the battery goes - tried several batteries - and tried them in other phones and are fine - thinking something shorting or draining it in the phone?
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 54
All Time: 5,141
