Repairing Nespresso Aeroccino Plus Motor
  1. Repairing Nespresso Aeroccino Plus Motor, Heat: step 1, image 1 of 1
    • Heat up to 50°C/120°F in oven in order to make the clips inside smooth.
    Ask FixBot
  2. Repairing Nespresso Aeroccino Plus Motor, Open: step 2, image 1 of 2 Repairing Nespresso Aeroccino Plus Motor, Open: step 2, image 2 of 2
    • Open the bottom with a strong screwdriver. Be careful not to break the clips inside
    Ask FixBot
  3. Repairing Nespresso Aeroccino Plus Motor, Prepare: step 3, image 1 of 2 Repairing Nespresso Aeroccino Plus Motor, Prepare: step 3, image 2 of 2
    • Pull out the circuit board and the motor. After module is removed the on/off pad must be pressed in/through
    Ask FixBot
  4. Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: step 4, image 1 of 3 Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: step 4, image 2 of 3 Repairing Nespresso Aeroccino Plus Motor, Swap Motor Contacts: step 4, image 3 of 3
    • Check motor operation by pulling connector and applying 9V with an external power source (battery or bench supply) to the plug.
    • If the motor turns with reversed polarity then proceed by swapping black and red contacts leading to the motor. With a little flathead screwdriver press the contact spring, pull out the cable.
    • If the motor only turns by applying external power and a little twist or not at all, only solution is to replace the motor. Mabuchi RF-500TB-12560 is readily available on the internet.
    Ask FixBot
  5. Repairing Nespresso Aeroccino Plus Motor, Close: step 5, image 1 of 1
    • Carefully embed the thermal contact in conducting paste. Then press bottom into body until you hear a clic three times. At last switch must be pressed in.
    Ask FixBot
To proof the function use water.
36 other people completed this guide.
VauWeh
335,961 Reputation
311 Guides authored
49 Guide Comments
Bravo, vielen Dank. Hat bestens funktioniert, in 5 min war alles erledigt!
jschiedermair - Reply Share
Many thanks!
I couldn't believe reversing polarity would work, but it did!
J.
jeroenvaneijk - Reply Share
Yes, it's a miracle. :-)
VauWeh - Reply Share
If reversing the wires solves your problem then it was just a loose or poor contact at the switch causing the problem.
You are not switching polarity when swapping the wires. Like a light switch, it only serves as a connection/disconnection point for electrical flow.
ekao - Reply Share
Gibt's da auch eine technische Begründung dazu, warum der bloße Tausch der Motoranschlüsse den Fehler behebt?
Ich würd's nur gerne verstehen.
Georg Sunkler - Reply Share
Past 24 Hours: 13
Past 7 Days: 73
Past 30 Days: 388
All Time: 125,191
