Repairing HTC Droid Incredible Digitizer
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
    1. Repairing HTC Droid Incredible Digitizer, Battery: step 1, image 1 of 3 Repairing HTC Droid Incredible Digitizer, Battery: step 1, image 2 of 3 Repairing HTC Droid Incredible Digitizer, Battery: step 1, image 3 of 3
      • Pry off back plastic, starting at the gap provided at the bottom of the phone. A spudger can be used to make this easier.
      Ask FixBot
    2. Repairing HTC Droid Incredible Digitizer: step 2, image 1 of 2 Repairing HTC Droid Incredible Digitizer: step 2, image 2 of 2
      • Remove battery, prying from the provided gap at the upper-right corner of the battery
      Ask FixBot
    1. Repairing HTC Droid Incredible Digitizer, Back Panel: step 3, image 1 of 2 Repairing HTC Droid Incredible Digitizer, Back Panel: step 3, image 2 of 2
      • Depress MicroSD to eject it from the side of the case.
      Ask FixBot
    2. Repairing HTC Droid Incredible Digitizer: step 4, image 1 of 3 Repairing HTC Droid Incredible Digitizer: step 4, image 2 of 3 Repairing HTC Droid Incredible Digitizer: step 4, image 3 of 3
      • Remove 4 corner screws, you may have to remove a "VOID" sticker from one of the screw heads.
      Ask FixBot
    3. Repairing HTC Droid Incredible Digitizer: step 5, image 1 of 3 Repairing HTC Droid Incredible Digitizer: step 5, image 2 of 3 Repairing HTC Droid Incredible Digitizer: step 5, image 3 of 3
      • Using a spudger, unclip the nine clips holding the back panel to the front panel, highlighted in included pictures.
      • Start at the top, and work clockwise, being careful not to break the clips.
      • There are, 1, 3, 2, and 3 clips on each side, respectively.
      • After the clips are disengaged, there are no cables holding the back panel in place.
      Ask FixBot
    1. Repairing HTC Droid Incredible Digitizer, Optical Track Pad: step 6, image 1 of 3 Repairing HTC Droid Incredible Digitizer, Optical Track Pad: step 6, image 2 of 3 Repairing HTC Droid Incredible Digitizer, Optical Track Pad: step 6, image 3 of 3
      • Use your spudger to release the jaw clip holding the Optical Track Pad cable to the logic board.
      • Remove Optical Track Pad from logic board.
      Ask FixBot
    1. Repairing HTC Droid Incredible Digitizer, Logic Board: step 7, image 1 of 1
      • Use your spudger to release the remaining clips, disconnecting the ribbon cables from the logic board.
      Ask FixBot
    2. Repairing HTC Droid Incredible Digitizer: step 8, image 1 of 2 Repairing HTC Droid Incredible Digitizer: step 8, image 2 of 2
      • Remove 2 Phillips Screws holding the logic board to the front panel.
      • Gently lift the logic board off the front panel.
      Ask FixBot
    1. Repairing HTC Droid Incredible Digitizer, LCD: step 9, image 1 of 2 Repairing HTC Droid Incredible Digitizer, LCD: step 9, image 2 of 2
      • Remove the two phillips screws from the top of the LCD frame.
      • Use your spudger to pry the LCD out of the frame.
      Ask FixBot
    1. Repairing HTC Droid Incredible Digitizer, Digitizer Assembly: step 10, image 1 of 2 Repairing HTC Droid Incredible Digitizer, Digitizer Assembly: step 10, image 2 of 2
      • Once the LCD has been removed from the frame, the Digitizer can be gently pushed out from the back.
      • Be sure to catch the speaker cover as it is released from the digitizer, you will need to replace it when reinstalling the digitizer.
      • There is adhesive tape holding the Digitizer to the front panel, heating around the edges of the digitizer will help to loosen it, if it sticks.
      • After the digitizer is removed, you may wish to remove the adhesive tape and reapply before replacing the digitizer.
      Ask FixBot
11 other people completed this guide.
Mobile Rapid Response Unit
1,941 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 34
Past 30 Days: 112
All Time: 6,585
