Repairing GEN 2 Wheelchair Patching a Tire Tube
    1. Repairing GEN 2 Wheelchair Patching a Tire Tube, Repairing GEN 2 Wheelchair Patching a Tire Tube: step 1, image 1 of 3 Repairing GEN 2 Wheelchair Patching a Tire Tube, Repairing GEN 2 Wheelchair Patching a Tire Tube: step 1, image 2 of 3 Repairing GEN 2 Wheelchair Patching a Tire Tube, Repairing GEN 2 Wheelchair Patching a Tire Tube: step 1, image 3 of 3
      • Unscrew the axle nut with a 19 mm wrench.
      • Unscrew the the axle bolt with a 19 mm socket wrench.
      • Remove the wheel from the wheelchair.
      Ask FixBot
    2. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 2, image 1 of 2 Repairing GEN 2 Wheelchair Patching a Tire Tube: step 2, image 2 of 2
      • Insert the 19 mm socket wrench between the rubber tire and the metal frame.
      • Any rigid flat metal object can be used for this step.
      • Carefully slide the 19 mm socket wrench all the way around the tire. Bend the wrench down to pop the tire out of the bead of the rim.
      • When undoing the tire, be careful using the back of the wrench because the tool can damage the tire tube and or wheel frame.
      • Reach inside the tire and remove the tube from the metal frame.
      Ask FixBot
    3. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 3, image 1 of 1
      • Take the inner tube from inside the tire and submerge the tube in water.
      • Squeeze the tube gently looking for bubbles from the tube in the water.
      • You can use where the bubbles are forming to locate the hole in the tube.
      Ask FixBot
    4. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 4, image 1 of 1
      • Dry off the tube.
      • Pull the tube out of the water and mark the location of the hole on the tube so that it can be found again.
      Ask FixBot
    5. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 5, image 1 of 1
      • Use sand paper to texturize the tire tube.
      • Wipe off any excess rubber that was sanded off the tube.
      Ask FixBot
    6. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 6, image 1 of 2 Repairing GEN 2 Wheelchair Patching a Tire Tube: step 6, image 2 of 2
      • Apply a thin layer of rubber cement over the area that was marked.
      • The layer should be slightly bigger than the size of the hole.
      • Let the rubber cement set for 5 minutes.
      • Peel the patch off of the plastic backing.
      • Place patch over the area with the rubber cement and firmly press down until the patch is securely attached.
      Ask FixBot
    7. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 7, image 1 of 1
      • Feel along the tire to check for and remove any objects stuck in the tire before replacing the tube.
      • Line up the air valve on the newly patched (partially deflated) tube with the hole on the metal frame before trying to insert the tube.
      • Working all around the tire, carefully push the tube back into place inside the tire.
      Ask FixBot
    8. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 8, image 1 of 1
      • Inflate the tire to 50 psi. If there is no gauge, inflate the tire until the tire is hard.
      Ask FixBot
    9. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 9, image 1 of 2 Repairing GEN 2 Wheelchair Patching a Tire Tube: step 9, image 2 of 2
      • Insert the axle bolt into the center of the rear wheel.
      • Insert the wheel with the axle bolt into the lower back of the frame by screwing in the bolt.
      Ask FixBot
    10. Repairing GEN 2 Wheelchair Patching a Tire Tube: step 10, image 1 of 2 Repairing GEN 2 Wheelchair Patching a Tire Tube: step 10, image 2 of 2
      • Secure the nut on the opposite side of the axle bolt and wheel. Tighten with 1/2 in or 19 mm wrench.
      Ask FixBot
Finish Line
2 other people completed this guide.
Kali Slaughter
257 Reputation
5 Guides authored
Cal Poly, Team 14-8, Maness Spring 2013 Member of Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Members
78 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 49
All Time: 1,189
