Repairing Flute Felt Key Pads
Views: 24K
View statistics:
Past 24 Hours:
13
Past 7 Days:
100
Past 30 Days:
312
All Time:
24,372
Comments: 2
2 comments on steps.
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The flute I'm about to show how to repair is a French Model flute (open hole keys). However, this method is applicable to the Plateau Model as well as other types of traditional concert flutes. If the connected keys on your flute aren't synchronized properly, follow step 1 and then skip ahead to step 40. If your flute has sticky keys, after following the first step, skip ahead to step 41. If your key has a missing pad, complete the first step and skip ahead to step 42. If your flute still won't play after completing these steps, then continue from step 2. Based on the location of the key needing repaired, some steps may not be necessary. Follow the instructions contained in the guide for details.
Parts
Tools
    1. Repairing Flute Felt Key Pads, Remove from Case: step 1, image 1 of 3 Repairing Flute Felt Key Pads, Remove from Case: step 1, image 2 of 3 Repairing Flute Felt Key Pads, Remove from Case: step 1, image 3 of 3
      • Do not grab the body of the flute by its keys when removing it from the case.
      • Instead, grasp it by the tenon section, where you won't put stress on the springs.
      • Remove the head piece in a similar fashion.
      • Avoid contact with the nickel-silver portion of the tenon when holding the head piece. The sweat from your skin leaves behind acids that can eventually corrode it.
      • Also, don't grab the head piece by its lip plate. If you are wearing a ring, you could scratch the embouchure hole.
      • It is okay to grab the foot joint by the bottom two keys (the ones connected to the B and C rollers).
      Ask FixBot
    2. Repairing Flute Felt Key Pads, Cut out a Strip of Rolling Paper: step 2, image 1 of 2 Repairing Flute Felt Key Pads, Cut out a Strip of Rolling Paper: step 2, image 2 of 2
      • Use a pair of scissors to cut out a small strip of rolling paper.
      • The size isn't critical, so don't worry if it doesn't look identical to the one in the guide.
      Ask FixBot
    3. Repairing Flute Felt Key Pads, Identifying the Misaligned Keys: step 3, image 1 of 3 Repairing Flute Felt Key Pads, Identifying the Misaligned Keys: step 3, image 2 of 3 Repairing Flute Felt Key Pads, Identifying the Misaligned Keys: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers to hold the rolling paper.
      • Press the key lightly on the paper and pull outward.
      • Try this at eight different angles from the center of the key.
      • If the felt pad is making proper contact, you should feel a drag. If you feel that there is little or no drag, then you have identified the key that needs to be repaired.
      • Hopefully, there is only one side of the key that has this issue. Otherwise, you may need a new felt pad.
      Ask FixBot
    4. Repairing Flute Felt Key Pads, Place Holding the Repair: step 4, image 1 of 1
      • Mark the felt pad and the metal next to it where you felt little or no contact.
      • This step is important! We will use this later as a reference for the fix.
      • If your misaligned key is located only on the foot joint: skip ahead to step 20 to avoid unnecessary disassembly.
      • For repairing a key located on the body: follow the proceeding steps until you've successfully disassembled the key of interest. There is no need to disassemble the flute any further, so follow the guide as far as necessary and then, skip ahead to either step 20 (if a key in the foot joint needs fixing) or step 22.
      Ask FixBot
    5. Repairing Flute Felt Key Pads, Removing Keys from the Body: step 5, image 1 of 2 Repairing Flute Felt Key Pads, Removing Keys from the Body: step 5, image 2 of 2
      • Remove the screw connected to the F, E, and D keys.
      • Keep track of which screw goes where for when you reassemble it.
      Ask FixBot
    6. Repairing Flute Felt Key Pads: step 6, image 1 of 2 Repairing Flute Felt Key Pads: step 6, image 2 of 2
      • Repeat this step for the rail below the first one.
      • The keys will become lose and the rails will become misaligned. Relax, this is supposed to happen!
      Ask FixBot
    7. Repairing Flute Felt Key Pads: step 7, image 1 of 2 Repairing Flute Felt Key Pads: step 7, image 2 of 2
      • On the other side of the flute, remove the screw connected to the same rail from the previous step.
      • That rail should be free when you loosen the screw.
      Ask FixBot
    8. Repairing Flute Felt Key Pads: step 8, image 1 of 3 Repairing Flute Felt Key Pads: step 8, image 2 of 3 Repairing Flute Felt Key Pads: step 8, image 3 of 3
      • Remove the rail that has the F, E, and D keys.
      • The long rail can budge to the left enough for the shorter rail to slip out.
      Ask FixBot
    9. Repairing Flute Felt Key Pads: step 9, image 1 of 2 Repairing Flute Felt Key Pads: step 9, image 2 of 2
      • The D key should be free to slide from the rail. Be sure not to lose it!
      Ask FixBot
    10. Repairing Flute Felt Key Pads: step 10, image 1 of 3 Repairing Flute Felt Key Pads: step 10, image 2 of 3 Repairing Flute Felt Key Pads: step 10, image 3 of 3
      • Push the rail out of the small groove.
      • Weave the two trill keys (D and D#) out from underneath the springs.
      • It's OKAY if they bend.
      Ask FixBot
    11. Repairing Flute Felt Key Pads: step 11, image 1 of 3 Repairing Flute Felt Key Pads: step 11, image 2 of 3 Repairing Flute Felt Key Pads: step 11, image 3 of 3
      • This step is not necessary unless your misaligned key is the B tab. If this is not your misaligned key, skip this step.
      • Remove the rod located at the bottom of the vertical rail.
      • All the rods are like long screws and it's all one piece.
      Ask FixBot
    12. Repairing Flute Felt Key Pads: step 12, image 1 of 3 Repairing Flute Felt Key Pads: step 12, image 2 of 3 Repairing Flute Felt Key Pads: step 12, image 3 of 3
      • Next, loosen the screw connected to the C, B flat, and A keys. This screw is actually a rod. Pull this rod out using your fingers.
      Ask FixBot
    13. Repairing Flute Felt Key Pads: step 13, image 1 of 3 Repairing Flute Felt Key Pads: step 13, image 2 of 3 Repairing Flute Felt Key Pads: step 13, image 3 of 3
      • Remove the C key. This will make the next steps easier to complete .
      • On the same rail, remove the rest of the keys (B flat and G).
      • There should be a point where it connects. Just pop it out and remove the rail.
      Ask FixBot
    14. Repairing Flute Felt Key Pads: step 14, image 1 of 3 Repairing Flute Felt Key Pads: step 14, image 2 of 3 Repairing Flute Felt Key Pads: step 14, image 3 of 3
      • The next step is to loosen the screw that holds the inline G keys.
      • Same drill: pull out the rod that holds it together.
      • There are a few rods involved in this disassembly. To avoid confusion, place them aside in an order that will remind you how to put them back.
      Ask FixBot
    15. Repairing Flute Felt Key Pads: step 15, image 1 of 3 Repairing Flute Felt Key Pads: step 15, image 2 of 3 Repairing Flute Felt Key Pads: step 15, image 3 of 3
      • To make the removal of the inline G keys easier, use tweezers to move the spring out of position.
      • The spring will hang loose for now.
      Ask FixBot
    16. Repairing Flute Felt Key Pads: step 16, image 1 of 2 Repairing Flute Felt Key Pads: step 16, image 2 of 2
      • The inline G keys should come out easily.
      • Now, loosen the rod connected to the G# lever.
      Ask FixBot
    17. Repairing Flute Felt Key Pads: step 17, image 1 of 2 Repairing Flute Felt Key Pads: step 17, image 2 of 2
      • This is the most difficult rod to remove, so to make it a little easier on yourself, get the spring out of the way by moving it up into the groove.
      • Don't worry about bending the spring too much. If it loses it's original tension, it can be easily be corrected by stretching it in the opposite direction.
      Ask FixBot
    18. Repairing Flute Felt Key Pads: step 18, image 1 of 2 Repairing Flute Felt Key Pads: step 18, image 2 of 2
      • Be careful when removing this rod! The spring opposing your direction of motion means business! You can use your free hand to hold it out of the way if necessary.
      • Carefully slide the rod out.
      Ask FixBot
    19. Repairing Flute Felt Key Pads: step 19, image 1 of 2 Repairing Flute Felt Key Pads: step 19, image 2 of 2
      • The G# lever should come out easily.
      • This is the last key to be removed from the body.
      • If you do not have a misaligned key on the foot joint, skip step 20 and step 21.
      Ask FixBot
    20. Repairing Flute Felt Key Pads, Removing Keys from the Foot Joint: step 20, image 1 of 3 Repairing Flute Felt Key Pads, Removing Keys from the Foot Joint: step 20, image 2 of 3 Repairing Flute Felt Key Pads, Removing Keys from the Foot Joint: step 20, image 3 of 3
      • Disassembling the foot joint is simple. Loosen the screw at the end of the rail and pull out the long rod holding it all together.
      • This is by far the longest rod in the flute!
      Ask FixBot
    21. Repairing Flute Felt Key Pads: step 21, image 1 of 2 Repairing Flute Felt Key Pads: step 21, image 2 of 2
      • When you pull out the rod, everything will fall apart. This is okay, it is what is supposed to happen. Just be sure not to lose any parts in the process!
      Ask FixBot
    22. Repairing Flute Felt Key Pads, Repairing the Finger Key: step 22, image 1 of 3 Repairing Flute Felt Key Pads, Repairing the Finger Key: step 22, image 2 of 3 Repairing Flute Felt Key Pads, Repairing the Finger Key: step 22, image 3 of 3
      • Once you've been able to remove the malfunctioning finger key, it is time to take it apart.
      • Be careful removing the screw, it is tiny, as well as nonmagnetic. It is very easy to lose!
      Ask FixBot
    23. Repairing Flute Felt Key Pads: step 23, image 1 of 2 Repairing Flute Felt Key Pads: step 23, image 2 of 2
      • Using the screwdriver, gently lift the pad out of the cup.
      • Behind the pad there will most likely be a couple paper shims that were placed there previously.
      • The items laid out left to right go in the cup from bottom to top, respectively.
      Ask FixBot
    24. Repairing Flute Felt Key Pads: step 24, image 1 of 3 Repairing Flute Felt Key Pads: step 24, image 2 of 3 Repairing Flute Felt Key Pads: step 24, image 3 of 3
      • The amount of additional paper shims you may need ultimately depends on the condition of the repair.
      • Using scissors, cut out about a third of a new paper shim.
      Ask FixBot
    25. Repairing Flute Felt Key Pads: step 25, image 1 of 3 Repairing Flute Felt Key Pads: step 25, image 2 of 3 Repairing Flute Felt Key Pads: step 25, image 3 of 3
      • Place the cut paper shim back into the cup after the supporting, whole shims. You may need to place more than one cut paper shim if the misalignment is more severe.
      • Important: Be sure that the orientation of the cut shim aligns with the mark made on the metal of the cup.
      • If your repaired key is located only on the body, skip ahead to step 29.
      Ask FixBot
    26. Repairing Flute Felt Key Pads, Reassembly of the Foot Joint: step 26, image 1 of 3 Repairing Flute Felt Key Pads, Reassembly of the Foot Joint: step 26, image 2 of 3 Repairing Flute Felt Key Pads, Reassembly of the Foot Joint: step 26, image 3 of 3
      • For the reassembly of the foot joint, the keys go back in this order:
      • C roller.
      • B roller.
      • This part has a "gizmo," which is a distinct tab attached to the roller.
      • C# touch.
      • D# touch (pinky key).
      Ask FixBot
    27. Repairing Flute Felt Key Pads: step 27, image 1 of 2 Repairing Flute Felt Key Pads: step 27, image 2 of 2
      • It's a bit tricky trying to keep all the pieces lined up when inserting the rod.
      • It's a bit easier to slide it in one section at a time, rather than trying to do them all in one shot.
      Ask FixBot
    28. Repairing Flute Felt Key Pads: step 28, image 1 of 2 Repairing Flute Felt Key Pads: step 28, image 2 of 2
      • You'll notice that all the keys aren't open. This is because the springs aren't in the proper place.
      • To fix this, use the ridged tweezers to grab the spring and put it behind the peg.
      • You may need to wrestle the spring a little bit. Try your best not to scratch the silver plating of the flute with the tweezers.
      • If your repaired key is located only on the foot joint, skip ahead to step 40.
      Ask FixBot
    29. Repairing Flute Felt Key Pads, Reassembly of the Body: step 29, image 1 of 2 Repairing Flute Felt Key Pads, Reassembly of the Body: step 29, image 2 of 2
      • When putting the G# lever back in place, make sure its spring is loaded against the post on the right.
      • Follow the disassembly directions in reverse order, as well as these steps to ensure that all the springs are put back in place. The flute doesn't need to be taken apart a second time.
      Ask FixBot
    30. Repairing Flute Felt Key Pads: step 30, image 1 of 2 Repairing Flute Felt Key Pads: step 30, image 2 of 2
      • After putting back the inline G keys, make sure to put back the spring behind the peg.
      • This is the only spring you removed during disassembly.
      Ask FixBot
    31. Repairing Flute Felt Key Pads: step 31, image 1 of 2 Repairing Flute Felt Key Pads: step 31, image 2 of 2
      • This is the spring by the C key.
      • Notice that the spring is in front of the metal groove.
      • Use the tweezers to put the spring behind it and in the groove.
      Ask FixBot
    32. Repairing Flute Felt Key Pads: step 32, image 1 of 3 Repairing Flute Felt Key Pads: step 32, image 2 of 3 Repairing Flute Felt Key Pads: step 32, image 3 of 3
      • This is the spring of the B flat key (next to the C key).
      • Again, this spring needs to go behind the small plate, into a little slot.
      Ask FixBot
    33. Repairing Flute Felt Key Pads: step 33, image 1 of 1
      • This spring needs to be put back behind its peg.
      • For reference, that plate with the spring in its groove is the spring that was fixed in the previous step.
      Ask FixBot
    34. Repairing Flute Felt Key Pads: step 34, image 1 of 2 Repairing Flute Felt Key Pads: step 34, image 2 of 2
      • If you did not remove the B tab, skip this step.
      • Align the two separate tabs so that the rod fits back through.
      • Make sure that the tip at the end of the skinny tab returns under its corresponding strip of metal.
      Ask FixBot
    35. Repairing Flute Felt Key Pads: step 35, image 1 of 2 Repairing Flute Felt Key Pads: step 35, image 2 of 2
      • In order for the reassembly to work for this piece, remember to put the trill keys under the corresponding springs.
      • Make sure the rail is rejoined at that point.
      • That tab fits behind the one fixed there.
      Ask FixBot
    36. Repairing Flute Felt Key Pads: step 36, image 1 of 3 Repairing Flute Felt Key Pads: step 36, image 2 of 3 Repairing Flute Felt Key Pads: step 36, image 3 of 3
      • After putting the screws back, fix the springs that connect to the trill keys.
      • It will be easier if you do the top one first.
      Ask FixBot
    37. Repairing Flute Felt Key Pads: step 37, image 1 of 2 Repairing Flute Felt Key Pads: step 37, image 2 of 2
      • These are the springs behind the F and E finger keys.
      • The top spring goes behind the peg.
      Ask FixBot
    38. Repairing Flute Felt Key Pads: step 38, image 1 of 3 Repairing Flute Felt Key Pads: step 38, image 2 of 3 Repairing Flute Felt Key Pads: step 38, image 3 of 3
      • The bottom spring goes behind the small plate in a groove.
      Ask FixBot
    39. Repairing Flute Felt Key Pads: step 39, image 1 of 3 Repairing Flute Felt Key Pads: step 39, image 2 of 3 Repairing Flute Felt Key Pads: step 39, image 3 of 3
      • This spring between the F and E keys isn't hard to reach. Fit it in the small groove.
      • The spring between the E and D keys goes behind a small peg.
      Ask FixBot
    40. Repairing Flute Felt Key Pads, Adjusting the Tension in Finger Keys: step 40, image 1 of 3 Repairing Flute Felt Key Pads, Adjusting the Tension in Finger Keys: step 40, image 2 of 3 Repairing Flute Felt Key Pads, Adjusting the Tension in Finger Keys: step 40, image 3 of 3
      • When putting your flute back together, some keys may seem either too easy or to hard to press. This is related to the tightness of the screws in the rails, as well as small screws between finger keys that have not yet been mentioned.
      • The tighter the screw, the more finger keys that will resist being closed.
      • To adjust the G# lever, change the tightness in the corresponding screw in the railing.
      • To adjust the inline G keys, play with the screw in the attached rail on top of the G# lever railing.
      • The B tab on the other side of the flute is also adjusted in this fashion.
      • This screw, as well as the next two screws in this step, do not hold anything together. They act as modifiers that adjust the synchronization of connected keys not attached to a rod backbone.
      • This alters the F and F# pair.
      • This screw changes the coordination of the D and F# keys.
      Ask FixBot
    41. Repairing Flute Felt Key Pads, Fixing Sticky Keys: step 41, image 1 of 3 Repairing Flute Felt Key Pads, Fixing Sticky Keys: step 41, image 2 of 3 Repairing Flute Felt Key Pads, Fixing Sticky Keys: step 41, image 3 of 3
      • When practicing the flute for a good amount of time, finger keys often get sticky. This can affect the time it takes for the pressed key to return to its original open position, something fast playing musicians can't afford.
      • Put an oil absorbing sheet under the sticky key and lightly press down on the sheet.
      • Release and gently remove the sheet.
      • DO NOT pull the sheet out like the rolling paper. This could lead to misalignment of the felt pad.
      • When cleaning the silver plating on the flute, do not wipe underneath the keys. Similarly, this could also lead to damage of the felt pads.
      • You'd be amazed by the amount of grime you might find trapped in the keys. Oil absorbing sheets work best to get the moisture out of the keys, in addition to the grime.
      • Dollar bills also can work, but not everyone has that kind of money.
      Ask FixBot
    42. Repairing Flute Felt Key Pads, Fixing a Finger Key with a Missing Felt Pad: step 42, image 1 of 3 Repairing Flute Felt Key Pads, Fixing a Finger Key with a Missing Felt Pad: step 42, image 2 of 3 Repairing Flute Felt Key Pads, Fixing a Finger Key with a Missing Felt Pad: step 42, image 3 of 3
      • In the case that you are missing a felt pad entirely (just a bare cup), you can still fix your flute temporarily.
      • Cut a small strip of teflon tape (about 4" )
      • Holding both ends, slip the tape under the key with the missing felt pad. It's quite the surgery, but manageable.
      • Make sure the part where the key makes contact with the body is fully covered.
      • With the remaining tape, twist it together at the top to hold it in place.
      • This is a temporary fix, but works perfectly.
      Ask FixBot
Finish Line
11 other people completed this guide.
Luke Williams
554 Reputation
2 Guides authored
Cal Poly, Team 10-1, Green Fall 2015 Member of Cal Poly, Team 10-1, Green Fall 2015
CPSU-GREEN-F15S10G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 13
Past 7 Days: 100
Past 30 Days: 312
All Time: 24,372
