Up to 20% off select tools
Repairing Alarm Clock Clock Projector
Views: 16K
View statistics:
Past 24 Hours:
12
Past 7 Days:
52
Past 30 Days:
205
All Time:
15,741
Comments: 8
2 comments on steps, 6 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
After several years, the clock projector of my RRM320P was missing some segments.
Suspecting that issue could be related to some poor electrical contact I decided to try to repair it
    1. Repairing Alarm Clock Clock Projector, The issue: step 1, image 1 of 1
      • The Problem: here I should read 12:47
      Ask FixBot
    2. Repairing Alarm Clock Clock Projector: step 2, image 1 of 2 Repairing Alarm Clock Clock Projector: step 2, image 2 of 2
      • After removing the 2 screws on the bottom, carefully open the bottom frame, see location of the plastic snaps snaps
      Ask FixBot
    3. Repairing Alarm Clock Clock Projector: step 3, image 1 of 3 Repairing Alarm Clock Clock Projector: step 3, image 2 of 3 Repairing Alarm Clock Clock Projector: step 3, image 3 of 3
      • Removes the back panel, taking care of the other plastic snaps
      • The projector and its optics is shown in the blue square
      Ask FixBot
    4. Repairing Alarm Clock Clock Projector, The optics: step 4, image 1 of 3 Repairing Alarm Clock Clock Projector, The optics: step 4, image 2 of 3 Repairing Alarm Clock Clock Projector, The optics: step 4, image 3 of 3
      • cables are tied together with a simple ribbon, in general the inner construction seems very cheap
      • The Projector is made of three parts:
      • A red LED
      • The display with its controller
      • the lens with focus mechanics
      • All parts are kept by tiny screws that you have to remove
      • Take extra caution when handling the display, the flat cable is very weak and can be damaged by improper handling
      Ask FixBot
    5. Repairing Alarm Clock Clock Projector: step 5, image 1 of 3 Repairing Alarm Clock Clock Projector: step 5, image 2 of 3 Repairing Alarm Clock Clock Projector: step 5, image 3 of 3
      • Carefully remove display from its supporting frame
      • The issue should be ralated to flat cable connecting display to controller
      Ask FixBot
    6. Repairing Alarm Clock Clock Projector: step 6, image 1 of 3 Repairing Alarm Clock Clock Projector: step 6, image 2 of 3 Repairing Alarm Clock Clock Projector: step 6, image 3 of 3
      • Verify that moving the flat the display returns to work
      • put a stiffner on controller side and close to the display
      • if everything is working, reassemble the clock by doing the steps in reverse order
      Ask FixBot
    7. Repairing Alarm Clock Clock Projector: step 7, image 1 of 1
      • Problem solved.
      Ask FixBot
6 other people completed this guide.
Author
with
Andrea Gangemi
172 Reputation
1 Guide authored
6 Guide Comments
The clock projection displays only partial numbers.one number is missing. The face on the clock displays perfect. It's just The projection on the wall that's missing a digit
eacoch - Reply Share
my Peakeep clock keeps the correct time but you can't see the time clearly. It's as if the light is turned off.
serena williams - Reply Share
Thank you for this post! It was the exact starting point to fix my projection clock which was looking dull and had lost a few segments. While the addition of supporting tape helped for a short period, doing it again in conjunction with Step 6 of the following link (http://www.instructables.com/id/How-to-r...) - Applying heat - to the ribbon contact points was the ticket that restored my projection clock functionality.
Adam - Reply Share
Hi Adam, glad to helped you
Andrea Gangemi - Reply Share
The display on my clock is missing parts of a number but project correct time , help ?
mandzb87 - Reply Share
Past 24 Hours: 12
Past 7 Days: 52
Past 30 Days: 205
All Time: 15,741
