Repair of a cat for therapy
    1. Repair of a cat for therapy, Push button: step 1, image 1 of 2 Repair of a cat for therapy, Push button: step 1, image 2 of 2
      • Remove six screws with Torx T10 on the backside of the device.
      Ask FixBot
    2. Repair of a cat for therapy: step 2, image 1 of 3 Repair of a cat for therapy: step 2, image 2 of 3 Repair of a cat for therapy: step 2, image 3 of 3
      • Just for information, it is NOT necessary to remove the printed circuit board! There are three connectors: speaker, battery and sensor.
      Ask FixBot
    3. Repair of a cat for therapy: step 3, image 1 of 3 Repair of a cat for therapy: step 3, image 2 of 3 Repair of a cat for therapy: step 3, image 3 of 3
      • Just for information, it is NOT necessary for the repair!
      Ask FixBot
    4. Repair of a cat for therapy: step 4, image 1 of 2 Repair of a cat for therapy: step 4, image 2 of 2
      • Button: pick the membrane and the adhesive stick up, clean with glass fiber brush and some Isopropyl alcohol. Let it dry, reassemble it. Fix it with some tape of Teflon.
      • Test it, you should feel the pressure point with a click.
      Ask FixBot
    5. Repair of a cat for therapy, Secure the membrane with adhesive tape: step 5, image 1 of 3 Repair of a cat for therapy, Secure the membrane with adhesive tape: step 5, image 2 of 3 Repair of a cat for therapy, Secure the membrane with adhesive tape: step 5, image 3 of 3
      • Example of securing with Teflon tape or similar thin adhesive tape.
      • I did not try the following: One could add a coil spring arround the white part of the push button of the case. The Spring could relieve the small button.
      Ask FixBot
    6. Repair of a cat for therapy: step 6, image 1 of 1
      • Assembly: put the case together, ensure the free move of the button, are all connectors in place?
      • Assembly: Use the six screws to fix the case.
      Ask FixBot
Just assemble in opposite order the steps to reassemble the device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Ee_Es
934 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 28
All Time: 323
