Up to 20% off select tools
Repair Mouse Buttons
Views: 130K
View statistics:
Past 24 Hours:
7
Past 7 Days:
65
Past 30 Days:
327
All Time:
130,100
Comments: 22
6 comments on steps, 16 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
From use and abuse, the bottoms of the mouse buttons can wear down and become unable to click the digital buttons inside the mouse.
    1. Repair Mouse Buttons, Engage Wired Optical Mouse Top and Outer Shell Removal: step 1, image 1 of 1
      • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
      Ask FixBot
    2. Repair Mouse Buttons: step 2, image 1 of 1
      • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
      • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
      Ask FixBot
    3. Repair Mouse Buttons: step 3, image 1 of 3 Repair Mouse Buttons: step 3, image 2 of 3 Repair Mouse Buttons: step 3, image 3 of 3
      • Grab the top shell of the mouse and lift up to remove.
      Ask FixBot
    4. Repair Mouse Buttons: step 4, image 1 of 1
      • The capacitors on this board can release stored electrical energy if touched.
      • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
      Ask FixBot
    5. Repair Mouse Buttons: step 5, image 1 of 2 Repair Mouse Buttons: step 5, image 2 of 2
      • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
      Ask FixBot
    1. Repair Mouse Buttons, Top Shell: step 6, image 1 of 1
      • Remove the 5 mm round head screw holding the middle piece to the top piece.
      • The outermost shell will now separate from the middle structure.
      Ask FixBot
    1. Repair Mouse Buttons, Repair Mouse Buttons: step 7, image 1 of 2 Repair Mouse Buttons, Repair Mouse Buttons: step 7, image 2 of 2
      • Take the plastic buttons (the part that your fingers click) and flip them over.
      • On the bottom, there should be little plastic towers. Wearing these down can prevent the buttons from clicking properly.
      Ask FixBot
    2. Repair Mouse Buttons: step 8, image 1 of 2 Repair Mouse Buttons: step 8, image 2 of 2
      • File the bottoms of these towers flat to remove any ridges that prevent proper clicking.
      • Make sure to file down both towers. In this image, one is left un-filed to show the difference.
      • This process can also be used for the other buttons on the mouse. Use other guides to disassemble the mouse until the desired button is accessible, and then perform the same filing technique.
      Ask FixBot
20 other people completed this guide.
Author
with
David
1,316 Reputation
4 Guides authored
Cal Poly, Team 18-36, Regan Winter 2013 Member of Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Members
84 Guides authored
16 Guide Comments
Thanks, worked like a charm.
Michael Beckman - Reply Share
i used a software fix and all my double random clicks has gone , mouserepair.com solved my problem for good.
Youns T - Reply Share
What if my gaming mouse doesnt have screws??
k2snakalle123 - Reply Share
yep no screws……….so am screwed
Nav Dugal - Reply Share
Really a great help!
Aman Kashyap - Reply Share
Past 24 Hours: 7
Past 7 Days: 65
Past 30 Days: 327
All Time: 130,100
