Repair Manual
  1. Repair Manual, Repair Manual: step 1, image 1 of 1
    • Turn on the computer and in this case, with ubuntu operating system
    • Next, if the operating system starts well on this computer, you have to check the settings
  2. Repair Manual: step 2, image 1 of 2 Repair Manual: step 2, image 2 of 2
    • In this case, there is a problem with the Wi-Fi
    • Then you have to verify everything has the correct configuration. We can use the cdm window to confirm the kernel parameters are set up correctly, with the SUDO command.
  3. Repair Manual: step 3, image 1 of 1
    • Finally, we need to confirm the WiFi is working. That will be all.
To reassemble your device, follow these instructions in reverse order
3 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
garby_007armando
415 Reputation
3 Guides authored
1 Guide Comment
Revisada la Guía faltaria completar mejor los pasos.
Carlos López (España - Spain) - Reply Share
Past 24 Hours: 7
Past 7 Days: 41
Past 30 Days: 211
All Time: 2,017
