Removing the Phone Keypad
    1. Removing the Phone Keypad, Removing the Back Panel: step 1, image 1 of 2 Removing the Phone Keypad, Removing the Back Panel: step 1, image 2 of 2
      • Orient the phone so that the phone model and other descriptive information is facing upward.
      • Locate the two silver screws near the hinge where the battery is housed.
      • Remove the silver screws using a Phillips head #2 screwdriver.
      Ask FixBot
    2. Removing the Phone Keypad: step 2, image 1 of 3 Removing the Phone Keypad: step 2, image 2 of 3 Removing the Phone Keypad: step 2, image 3 of 3
      • Pull off the back panel of the phone.
      • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
      Ask FixBot
    1. Removing the Phone Keypad, Keypad: step 3, image 1 of 2 Removing the Phone Keypad, Keypad: step 3, image 2 of 2
      • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
      Ask FixBot
    2. Removing the Phone Keypad: step 4, image 1 of 1
      • Lift the motherboard away from the phone housing.
      • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
      Ask FixBot
    3. Removing the Phone Keypad: step 5, image 1 of 2 Removing the Phone Keypad: step 5, image 2 of 2
      • Now that the motherboard has been lifted out of place, the keypad can be accessed.
      • Using your fingers push the buttons from the the phone toward the lifted motherboard.
      • Remove the keypad from the assembly.
      Ask FixBot
Elizabeth Kelly
501 Reputation
5 Guides authored
Clemson, Team 15-1, Benson Fall 2012 Member of Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 31
All Time: 1,470
