Removing the Logitech MBJ58 Scroll Wheel from its Mount
    1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Top cover: step 1, image 1 of 1
      • Hold the mouse so that the bottom is facing up.
      • Remove the single Phillips #1 screw from the bottom half of the mouse.
      Ask FixBot
    2. Removing the Logitech MBJ58 Scroll Wheel from its Mount: step 2, image 1 of 2 Removing the Logitech MBJ58 Scroll Wheel from its Mount: step 2, image 2 of 2
      • Place the mouse so that the bottom is resting against a hard surface.
      • Lift the top cover of the mouse gently, and remove it.
      Ask FixBot
    1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 1 of 3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 2 of 3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: step 3, image 3 of 3
      • Locate the scroll wheel on the mouse.
      • Grab the scroll wheel with your thumb and index finger.
      • Gently lift up, to remove the scroll wheel from the mouse.
      Ask FixBot
    1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: step 4, image 1 of 2 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: step 4, image 2 of 2
      • Locate the spring on the scroll wheel, and carefully remove the spring.
      Ask FixBot
    2. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: step 5, image 1 of 2 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: step 5, image 2 of 2
      • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
      Ask FixBot
    1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: step 6, image 1 of 3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: step 6, image 2 of 3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: step 6, image 3 of 3
      • Locate the black wheel mount.
      • Note: Make sure that the spring hidden in the mount does not fall out.
      • Separate the wheel from its mount.
      Ask FixBot
2 other people completed this guide.
Conor Whatley
510 Reputation
3 Guides authored
Cal Poly, Team 5-14, Forte Winter 2013 Member of Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Members
84 Guides authored
2 Guide Comments
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - Reply Share
Very helpful, thank you!
K.S. - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 71
All Time: 2,462
