Removing the HP Elitebook 6930p WLAN Module
    1. Removing the HP Elitebook 6930p WLAN Module, Battery Removal: step 1, image 1 of 3 Removing the HP Elitebook 6930p WLAN Module, Battery Removal: step 1, image 2 of 3 Removing the HP Elitebook 6930p WLAN Module, Battery Removal: step 1, image 3 of 3
      • Flip laptop over and locate the battery release button
      • Push release button to the left to release battery and gently pull battery from the laptop
      Ask FixBot
    1. Removing the HP Elitebook 6930p WLAN Module, Keyboard: step 2, image 1 of 3 Removing the HP Elitebook 6930p WLAN Module, Keyboard: step 2, image 2 of 3 Removing the HP Elitebook 6930p WLAN Module, Keyboard: step 2, image 3 of 3
      • Loosen the three Phillips 2.5×9.0 captive screws that secure the keyboard to the laptop
      • Turn the laptop so the keyboard is facing up and locate the 4 retention tabs along the back edge of the keyboard
      • Slide the retention clips toward the keyboard to release the keyboard
      Ask FixBot
    2. Removing the HP Elitebook 6930p WLAN Module: step 3, image 1 of 3 Removing the HP Elitebook 6930p WLAN Module: step 3, image 2 of 3 Removing the HP Elitebook 6930p WLAN Module: step 3, image 3 of 3
      • Use a plastic pry tool to lift the rear edge of the keyboard.
      • Pull the keyboard slightly towards the display to disengage the tabs along the front of the keyboard from the laptop palm rest.
      • Lift the keyboard up to reveal the ribbon connectors
      Ask FixBot
    3. Removing the HP Elitebook 6930p WLAN Module: step 4, image 1 of 3 Removing the HP Elitebook 6930p WLAN Module: step 4, image 2 of 3 Removing the HP Elitebook 6930p WLAN Module: step 4, image 3 of 3
      • Release the larger ribbon cable by flipping the brown retainer up so it is parallel with the ribbon cable
      • Release the smaller ribbon cable by lifting up the white retainer
      • I found it easier to reinstall both cables with the new keyboard resting on the back edge
      Ask FixBot
    1. Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: step 5, image 1 of 3 Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: step 5, image 2 of 3 Removing the HP Elitebook 6930p WLAN Module, WLAN (WiFi) Module: step 5, image 3 of 3
      • Locate the WLAN module
      • Use a plastic spugder or similar to carefully remove the 3 antenna wires from the WLAN module.
      • The antenna wires are colour coded tabs on them for easy reinstallation so be sure to take note of the correct order. there are coloured tabs on the wires!
      • Remove the 2 M2.5×4.0 screws that secure the WLAN module into the laptop
      • With the screws removed the right hand end of the WLAN module will pop up. You may now simply remove the module from the edge connector.
      Ask FixBot
3 other people completed this guide.
Richdave
32,882 Reputation
30 Guides authored
Master Techs Member of Master Techs
Community
336 Members
8,282 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 40
Past 30 Days: 115
All Time: 9,165
