Removing the HP Compaq dx2000MT Optical (CD) Drive
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: step 1, image 1 of 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
    Ask FixBot
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: step 2, image 1 of 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 2, image 2 of 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
    Ask FixBot
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: step 3, image 1 of 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 3, image 2 of 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 3, image 3 of 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
    Ask FixBot
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: step 4, image 1 of 1
    • Remove the two Torx T15 screws that secure the case door to the device.
    Ask FixBot
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive: step 5, image 1 of 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 5, image 2 of 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 5, image 3 of 3
    • Once again, this may take considerable force.
    Ask FixBot
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: step 6, image 1 of 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: step 6, image 2 of 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: step 6, image 3 of 3
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
    Ask FixBot
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: step 7, image 1 of 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 7, image 2 of 2
    • Remove the 2 Torx T15 screws holding the optical drive in place.
    Ask FixBot
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: step 8, image 1 of 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 8, image 2 of 2
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
    Ask FixBot
  9. Removing the HP Compaq dx2000MT Optical (CD) Drive: step 9, image 1 of 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 9, image 2 of 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: step 9, image 3 of 3
    • Remove the optical drive by sliding it out the front of the device.
    Ask FixBot
Logan Pace
2,414 Reputation
9 Guides authored
Cal Poly, Team 17-16, Regan Fall 2011 Member of Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Members
17 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 33
All Time: 1,903
