Removing the Dell Inspiron 1150 Display Assembly
    1. Removing the Dell Inspiron 1150 Display Assembly, Battery: step 1, image 1 of 3 Removing the Dell Inspiron 1150 Display Assembly, Battery: step 1, image 2 of 3 Removing the Dell Inspiron 1150 Display Assembly, Battery: step 1, image 3 of 3
      • Place the laptop upside down on a clean, flat surface.
      • Locate the battery release button with the padlock symbol above it.
      • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
      • The battery is now released from the battery compartment.
      • Gently remove the battery from the side of the laptop.
      Ask FixBot
    1. Removing the Dell Inspiron 1150 Display Assembly, Hard Drive: step 2, image 1 of 2 Removing the Dell Inspiron 1150 Display Assembly, Hard Drive: step 2, image 2 of 2
      • Place laptop upside down on a clean flat surface.
      • Remove 2ea M2.5 x 5 mm screws.
      • Pull the HDD from main body of the laptop.
      Ask FixBot
    1. Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): step 3, image 1 of 3 Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): step 3, image 2 of 3 Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): step 3, image 3 of 3
      • Place laptop upsid down on a clean flat work surface.
      • Remove the Philips M2.5 x 8 mm screw
      • Loosen the screw that holds the memory compartment closed
      • remove the memory module compartment cover
      • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
      Ask FixBot
    1. Removing the Dell Inspiron 1150 Display Assembly, Keyboard: step 4, image 1 of 3 Removing the Dell Inspiron 1150 Display Assembly, Keyboard: step 4, image 2 of 3 Removing the Dell Inspiron 1150 Display Assembly, Keyboard: step 4, image 3 of 3
      • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
      • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
      • Lift the hinge cover off and set aside
      Ask FixBot
    2. Removing the Dell Inspiron 1150 Display Assembly: step 5, image 1 of 3 Removing the Dell Inspiron 1150 Display Assembly: step 5, image 2 of 3 Removing the Dell Inspiron 1150 Display Assembly: step 5, image 3 of 3
      • Remove 4ea M2 x 3mm keyboard screws
      • Lift up keyboard from the rear to expose the connector below
      • Disconnect the keyboard ribbon cable from the mother board
      Ask FixBot
    1. Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: step 6, image 1 of 3 Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: step 6, image 2 of 3 Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: step 6, image 3 of 3
      • Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
      • Remove the EMI shield to expose the LCD ribbon cable
      • Gently pull up on the tab to disconnect the ribbon cable from the main board
      • Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
      Ask FixBot
    2. Removing the Dell Inspiron 1150 Display Assembly: step 7, image 1 of 3 Removing the Dell Inspiron 1150 Display Assembly: step 7, image 2 of 3 Removing the Dell Inspiron 1150 Display Assembly: step 7, image 3 of 3
      • Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed
      • Remove 2e M2.5 x 5mm screws from each hinge bracket
      • The Display Assembly can now be lifted free of the laptop body
      Ask FixBot
2 other people completed this guide.
Daniel
87 Reputation
2 Guides authored
Cal Poly, Team 16-2, Maness Spring 2010 Member of Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 110
All Time: 7,465
