Removing the Apple Cinema Display M8149 Display Hinge
  1. Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: step 1, image 1 of 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: step 1, image 2 of 3 Removing the Apple Cinema Display M8149 Display Hinge, Display Hinge: step 1, image 3 of 3
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screwdriver, unscrew the three feet screws (9.52 x 4.43 mm).
    • Remove the back foot from the hinge mount by gently pulling it upwards.
    Ask FixBot
  2. Removing the Apple Cinema Display M8149 Display Hinge: step 2, image 1 of 3 Removing the Apple Cinema Display M8149 Display Hinge: step 2, image 2 of 3 Removing the Apple Cinema Display M8149 Display Hinge: step 2, image 3 of 3
    • Remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
    Ask FixBot
  3. Removing the Apple Cinema Display M8149 Display Hinge: step 3, image 1 of 2 Removing the Apple Cinema Display M8149 Display Hinge: step 3, image 2 of 2
    • Remove the Apple Display Connector plate screws (9.52 x 3.43 mm) with the PH 2 screwdriver.
    • Once the two screws have been removed, move the cord out of the way.
    Ask FixBot
  4. Removing the Apple Cinema Display M8149 Display Hinge: step 4, image 1 of 3 Removing the Apple Cinema Display M8149 Display Hinge: step 4, image 2 of 3 Removing the Apple Cinema Display M8149 Display Hinge: step 4, image 3 of 3
    • Remove the hinge plate screws (5.52 x 3.43 mm) with the PH 2 screw driver.
    • Then lift out the hinge mount.
    Ask FixBot
4 other people completed this guide.
Thomas Harper
268 Reputation
1 Guide authored
Cal Poly, Team 10-41, Forte Spring 2011 Member of Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Members
18 Guides authored
1 Guide Comment
in 2023 where can I get a replacement stand?
Mitch Leung - Reply Share
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 102
All Time: 8,697
